Mpg Question
Old 06-18-2014, 01:02 PM
Craig.Parks's Avatar
Craig.Parks
Craig.Parks is offline
Mpg Question
We recently took at trip from Houston to New Braunfels towing a 32ft 5th wheel.
Total gross weight ~ 19.5K. Scanguage average mpg was 8.1 Averaging 65 mph.
Tow vehicle is '04 6.0 4wd CCSB.
Also had an '02 7.3 4wd CCSB traveling with us with a lighter trailer and he was averaging 13-14mpg.
Is ~8mpg what most people are seeing while towing with 4wd & 6.0 ?
The good news is the temp delta stayed around 10*!
Old 06-18-2014, 02:31 PM
lupuseven's Avatar
lupuseven
lupuseven is offline
YouTube Certified Mech
Took a 10k trailer bumper pull, plus about 1k in the bed from Southern California to Dallas Texas last year I was averaging 13mpg 65-75mph. Early '04 CC LB SRW 4x4 6.0l, 99% stock. The high speeds didn't help at all. I avg 20-22mpg at 70mph empty.
******** charset="UTF-8" src="chrome://hdv/content/hdv.js" type="application/javascript">*********>
Old 06-18-2014, 02:37 PM
texastech_diesel's Avatar
texastech_diesel
texastech_diesel is offline
Token Redneck
I'd blame the ScanGauge. Use a pen and paper and report back after several complete tanks, and not one short <200 mile run.
Old 06-18-2014, 02:45 PM
Money-Pit's Avatar
Money-Pit
Money-Pit is offline
Yea, don't trust the Scangauge...mine has never been accurate.
Old 06-18-2014, 03:04 PM
Rellick's Avatar
Rellick
Rellick is offline
When i got my SG2, i forgot to run thru the set up and it was getting pretty ugly mileage.
Old 06-18-2014, 08:47 PM
Craig.Parks
Ok my scangauage and hand calculation are usually pretty close but after hand calculating this trip the average was 10.7.
That's a little better for sure.
Old 06-18-2014, 09:59 PM
Yahiko's Avatar
Yahiko
Yahiko is offline
I didn't bother with the MPG stuff on the SGII.
I use my iPhone and an app called RoadTrip.
Just enter the odometer and the gallons.
There is 2 ver. One is free and the other is a few $
and lets you also track maintenance stuff.
Handy app.
Sean
Old 06-18-2014, 11:36 PM
shivaskeeper's Avatar
shivaskeeper
shivaskeeper is offline
Just finished a 3000+ mile trip hauling a 40ft goose neck from Tacoma, WA to Custer, SD and returning through northern Montana.
Total gross weight ~ 29,000lbs
Tow vehicle ~ early '04 6.0 FX4, LB, SRW, super cab, mostly stock
Average MPG was about 10.5 MPG averaging 60-65mph on flat ground. MPG would drop into the 7-8 MPG on the long slogs up some of those mountain passes on I90. Mileage worked out by dividing the miles between fuel stops by how much I put in. Since I have a bad habit of filling the tank to the top of the filler neck I know I'm getting the right amount of fuel in for the calculation.
Greg
Old 06-19-2014, 09:22 AM
Craig.Parks
Thanks for providing your average Greg.
Sean - I will check out that app.
Old 06-19-2014, 10:00 AM
Lubbockguy1979's Avatar
Lubbockguy1979
Lubbockguy1979 is offline
Just moved from dallas to lubbock. Averaged 9mpg with a 8x16 enclosed trailer that was loaded. Ran the speed limit plus 70-80 mph. Generally in the metroplex I saw 14-16 depending on my drivin
Old 06-19-2014, 04:09 PM
Yahiko's Avatar
Yahiko
Yahiko is offline
I should of posted this sooner but here are some screen snots of Road Trip
Some of the older data is missing because I did a clean setup.
Also you can export all the data to you computer and even with a
little work you can export a trip and convert it so that all you logged stop
points can be shown on Google Maps. But that does take some work.
Sean
Old 06-20-2014, 11:17 AM
TinMan289's Avatar
TinMan289
TinMan289 is offline
Damn, Yahiko - that's thorough!
Unladen I see roughly 18-20 at 75 mph.
Haven't bothered to calc under load yet.
Old 06-20-2014, 11:42 AM
Yahiko's Avatar
Yahiko
Yahiko is offline
You should see the reports you can make from the exported data.
I had a lot more date in my history but wanted to clean some things up
and so I started from scratch. That is why there is not that much right now.
But one of the handy things is having it tell you that there is an oil change
coming up or time to change the coolant filter.
Sean
Wingit929
Conventional (Bumper Pull) Towing; Travel Trailers & Pop-ups
22
05-12-2016 09:30 AM
ffengine51
6.7L Power Stroke Diesel
18
10-05-2011 07:09 PM
SLMDLM
07-29-2009 02:50 PM
ludie
Fifth Wheel & Gooseneck RV Towing
02-11-2009 08:37 AM
f250meangreen
08-09-2006 10:15 AM
Quick Reply: Mpg Question
