Mpg Question - Ford Truck Enthusiasts Forums
Mpg Question
Old 06-18-2014, 01:02 PM
Craig.Parks's Avatar
Craig.Parks Craig.Parks is offline
Craig.Parks is starting off with a positive reputation.
Mpg Question
We recently took at trip from Houston to New Braunfels towing a 32ft 5th wheel.
Total gross weight ~ 19.5K. Scanguage average mpg was 8.1 Averaging 65 mph.
Tow vehicle is '04 6.0 4wd CCSB.
Also had an '02 7.3 4wd CCSB traveling with us with a lighter trailer and he was averaging 13-14mpg.
Is ~8mpg what most people are seeing while towing with 4wd & 6.0 ?
The good news is the temp delta stayed around 10*!
Old 06-18-2014, 02:31 PM
lupuseven's Avatar
lupuseven lupuseven is offline
lupuseven has a great reputation on FTE.lupuseven has a great reputation on FTE.lupuseven has a great reputation on FTE.lupuseven has a great reputation on FTE.
Took a 10k trailer bumper pull, plus about 1k in the bed from Southern California to Dallas Texas last year I was averaging 13mpg 65-75mph. Early '04 CC LB SRW 4x4 6.0l, 99% stock. The high speeds didn't help at all. I avg 20-22mpg at 70mph empty.
******** charset="UTF-8" src="chrome://hdv/content/hdv.js" type="application/javascript">*********>
Old 06-18-2014, 02:37 PM
texastech_diesel's Avatar
texastech_diesel texastech_diesel is offline
Disgruntled Texan
texastech_diesel has a superb reputationtexastech_diesel has a superb reputationtexastech_diesel has a superb reputationtexastech_diesel has a superb reputationtexastech_diesel has a superb reputationtexastech_diesel has a superb reputationtexastech_diesel has a superb reputationtexastech_diesel has a superb reputationtexastech_diesel has a superb reputationtexastech_diesel has a superb reputationtexastech_diesel has a superb reputation
I'd blame the ScanGauge. Use a pen and paper and report back after several complete tanks, and not one short <200 mile run.
Old 06-18-2014, 02:45 PM
Money-Pit's Avatar
Money-Pit Money-Pit is offline
Money-Pit is a splendid one to beholdMoney-Pit is a splendid one to beholdMoney-Pit is a splendid one to beholdMoney-Pit is a splendid one to beholdMoney-Pit is a splendid one to beholdMoney-Pit is a splendid one to beholdMoney-Pit is a splendid one to behold
Yea, don't trust the Scangauge...mine has never been accurate.
Old 06-18-2014, 03:04 PM
Rellick's Avatar
Rellick Rellick is offline
Rellick has a good reputation on FTE.Rellick has a good reputation on FTE.
When i got my SG2, i forgot to run thru the set up and it was getting pretty ugly mileage.
Old 06-18-2014, 08:47 PM
Ok my scangauage and hand calculation are usually pretty close but after hand calculating this trip the average was 10.7.
That's a little better for sure.
Old 06-18-2014, 09:59 PM
Yahiko's Avatar
Yahiko Yahiko is online now
Yahiko has a superb reputationYahiko has a superb reputationYahiko has a superb reputationYahiko has a superb reputationYahiko has a superb reputationYahiko has a superb reputationYahiko has a superb reputationYahiko has a superb reputationYahiko has a superb reputationYahiko has a superb reputationYahiko has a superb reputation
I didn't bother with the MPG stuff on the SGII.
I use my iPhone and an app called RoadTrip.
Just enter the odometer and the gallons.
There is 2 ver. One is free and the other is a few $
and lets you also track maintenance stuff.
Handy app.
Sean
Old 06-18-2014, 11:36 PM
shivaskeeper shivaskeeper is offline
shivaskeeper is starting off with a positive reputation.
Just finished a 3000+ mile trip hauling a 40ft goose neck from Tacoma, WA to Custer, SD and returning through northern Montana.
Total gross weight ~ 29,000lbs
Tow vehicle ~ early '04 6.0 FX4, LB, SRW, super cab, mostly stock
Average MPG was about 10.5 MPG averaging 60-65mph on flat ground. MPG would drop into the 7-8 MPG on the long slogs up some of those mountain passes on I90. Mileage worked out by dividing the miles between fuel stops by how much I put in. Since I have a bad habit of filling the tank to the top of the filler neck I know I'm getting the right amount of fuel in for the calculation.
Greg
Old 06-19-2014, 09:22 AM
Thanks for providing your average Greg.
Sean - I will check out that app.
Old 06-19-2014, 10:00 AM
Lubbockguy1979's Avatar
Lubbockguy1979 Lubbockguy1979 is offline
Lubbockguy1979 has a very good reputation on FTE.Lubbockguy1979 has a very good reputation on FTE.Lubbockguy1979 has a very good reputation on FTE.
Just moved from dallas to lubbock. Averaged 9mpg with a 8x16 enclosed trailer that was loaded. Ran the speed limit plus 70-80 mph. Generally in the metroplex I saw 14-16 depending on my drivin
Old 06-19-2014, 04:09 PM
Yahiko's Avatar
I should of posted this sooner but here are some screen snots of Road Trip
Some of the older data is missing because I did a clean setup.
Also you can export all the data to you computer and even with a
little work you can export a trip and convert it so that all you logged stop
points can be shown on Google Maps. But that does take some work.
Sean
Old 06-20-2014, 11:17 AM
TinMan289 TinMan289 is offline
TinMan289 has a good reputation on FTE.TinMan289 has a good reputation on FTE.
Damn, Yahiko - that's thorough!
Unladen I see roughly 18-20 at 75 mph.
Haven't bothered to calc under load yet.
Old 06-20-2014, 11:42 AM
Yahiko's Avatar
You should see the reports you can make from the exported data.
I had a lot more date in my history but wanted to clean some things up
and so I started from scratch. That is why there is not that much right now.
But one of the handy things is having it tell you that there is an oil change
coming up or time to change the coolant filter.
Sean
The official -TOWING- mpg Poll Krewat Modular V10 (6.8l) 113 03-08-2015 07:06 PM
3V vs. 2V MPG? tobyw Modular V10 (6.8l) 10 02-13-2015 08:18 AM
New from south central Texas mgreen18 New Member Introductions 0 02-01-2015 03:17 PM
Rot T6 on sale in central TX @ AZone FordFamily6 6.0L Power Stroke Diesel 7 11-16-2014 01:37 PM
5 mpg now...... wtf! straightaxle Modular V10 (6.8l) 82 04-26-2011 10:53 AM
Search this Thread:
Advanced Search
Posting Rules
You may not post new threads
You may not post replies
You may not post attachments
You may not edit your posts
BB code is On
Smilies are On
[IMG] code is On
HTML code is Off
Trackbacks are Off
Pingbacks are Off
Refbacks are Off
Forum Jump
