How much horsepower does a stock 7.3L have??? - Ford Truck Enthusiasts Forums
Old 06-18-2014, 01:22 PM
bobiker bobiker is offline
bobiker is starting off with a positive reputation.
Pretty straight forward in the title.
Old 06-18-2014, 01:29 PM
Macmathews Macmathews is offline
Macmathews is starting off with a positive reputation.
somethere in the 250 range..
BigAlsPSD's Avatar
BigAlsPSD BigAlsPSD is offline
BigAlsPSD has much to be proud ofBigAlsPSD has much to be proud ofBigAlsPSD has much to be proud ofBigAlsPSD has much to be proud ofBigAlsPSD has much to be proud ofBigAlsPSD has much to be proud ofBigAlsPSD has much to be proud ofBigAlsPSD has much to be proud ofBigAlsPSD has much to be proud ofBigAlsPSD has much to be proud of
Depends on the year model and auto vs manual, but around 235HP is the rating that is on the engine.
Old 06-18-2014, 01:53 PM
JOHN2001's Avatar
JOHN2001 JOHN2001 is offline
JOHN2001 is a splendid one to beholdJOHN2001 is a splendid one to beholdJOHN2001 is a splendid one to beholdJOHN2001 is a splendid one to beholdJOHN2001 is a splendid one to beholdJOHN2001 is a splendid one to beholdJOHN2001 is a splendid one to beholdJOHN2001 is a splendid one to behold
If you drive a diesel you shouldn't care as much about Hp as torque.... That's around 525 iirc
Old 06-18-2014, 01:56 PM
Quote:
Well im looking a dp tuner adding 336 hp. Which also adds torque.
Old 06-18-2014, 02:15 PM
hydro man 17 hydro man 17 is offline
hydro man 17 is gaining momentum as a positive member of FTE.hydro man 17 is gaining momentum as a positive member of FTE.
Adding 336 HP with just a tuner ain't going to happen, unless you mean ending up at 336. That could be doable with a couple of other additions.
Old 06-18-2014, 02:17 PM
Quote:
Total exhaust and intake
Old 06-18-2014, 02:22 PM
thomabb's Avatar
thomabb thomabb is offline
thomabb is a name known to allthomabb is a name known to allthomabb is a name known to allthomabb is a name known to allthomabb is a name known to allthomabb is a name known to all
250hp/505 lbft torque = auto transmission
275hp/525 lbft torque = manual transmission
Power Stroke Diesel Timeline
Old 06-18-2014, 02:49 PM
River19's Avatar
River19 River19 is offline
River19 has a good reputation on FTE.River19 has a good reputation on FTE.
I think you would be lucky to see something like 210 HP at the wheels stock.
Are you doing the simple math of Stock = 250 then DPs 80DD tune must be 330HP then?
I believe more goes into it than that. IIRC it would take more than just intake, exhaust and a stock DP tune to get to 330 HP at the rear wheels.......heck I think 325-350hp is the sweet spot for ACs vs. the stock sticks, unless you like high EGTs.....
BTW, you slapping gauges on that rig?
Old 06-18-2014, 03:12 PM
Christof13T's Avatar
Christof13T Christof13T is offline
Christof13T has a brilliant futureChristof13T has a brilliant futureChristof13T has a brilliant futureChristof13T has a brilliant futureChristof13T has a brilliant futureChristof13T has a brilliant futureChristof13T has a brilliant futureChristof13T has a brilliant futureChristof13T has a brilliant futureChristof13T has a brilliant futureChristof13T has a brilliant future
If you put a dip chip on it...
Just sayin...
You will be locked into buying tunes from dp.
Putting a chip on it should be last on the list for performance modifications.
Gauges. Gauges. Gauges!
Air in and out.
Fuel system updating.
Turbo compressor wheel at least.
You really should make sure your engine is healthy enough #1 and get it to 100% healthy in the stock configuration before trying to add power.
Throwing a chip on it and stomping the go pedal is a great way to end up looking for a replacement engine sooner than you would like.
Old 06-18-2014, 06:43 PM
twg1966's Avatar
twg1966 twg1966 is offline
Trying to Gain Knowledge
twg1966 is a name known to alltwg1966 is a name known to alltwg1966 is a name known to alltwg1966 is a name known to alltwg1966 is a name known to alltwg1966 is a name known to all
I agree with Chris. The best route to take is make every thing in the rig tight and leak free. Then put gauges on the rig. Then after you get to know your rig a little after the gauges, then and only then proceed to chipping.
Good luck.
Old 06-18-2014, 07:31 PM
hhowell1990's Avatar
hhowell1990 hhowell1990 is offline
hhowell1990 is starting off with a positive reputation.
These are the dyno runs from my truck about 2 months ago, the top two are with dp's 120hp tune and the bottom two are the "stock" tune
Old 06-18-2014, 08:43 PM
HKusp's Avatar
HKusp HKusp is offline
HKusp has a spectacular reputation.HKusp has a spectacular reputation.HKusp has a spectacular reputation.HKusp has a spectacular reputation.HKusp has a spectacular reputation.HKusp has a spectacular reputation.HKusp has a spectacular reputation.HKusp has a spectacular reputation.HKusp has a spectacular reputation.HKusp has a spectacular reputation.HKusp has a spectacular reputation.
The '02-'03's were rated 250/550 stock at the flywheel. You need air in, air out like Chris said. You need gauges to monitor for safety of the engine and tranny, and good tuning. Stock sticks and turbo, you won't see 350hp at the wheels.
Old 06-18-2014, 10:35 PM
materthegreater's Avatar
materthegreater materthegreater is offline
materthegreater is gaining momentum as a positive member of FTE.
This is slightly off topic, but does anyone know what the "7.3 calibration" means in the 2001 notes from this link? It doesn't say anything about hardware changes, so does that mean it's something in the computer?
Old 06-18-2014, 11:38 PM
cleatus12r cleatus12r is offline
cleatus12r has a spectacular reputation.cleatus12r has a spectacular reputation.cleatus12r has a spectacular reputation.cleatus12r has a spectacular reputation.cleatus12r has a spectacular reputation.cleatus12r has a spectacular reputation.cleatus12r has a spectacular reputation.cleatus12r has a spectacular reputation.cleatus12r has a spectacular reputation.cleatus12r has a spectacular reputation.cleatus12r has a spectacular reputation.
Torque accomplishes nothing without at the very least a time reference.
Horsepower is the only thing that matters when trying to get something done.
A stock-ish 99-03 7.3L will put down right about 200 RWHP.
**** bradphx 1973 - 1979 F-100 & Larger F-Series Trucks 59 12-05-2016 04:27 PM
ooops Aerostar 5 01-14-2015 04:16 AM
... miko6810 Modular V10 (6.8l) 9 06-04-2014 07:14 AM
Albums 56panelford 1948 - 1956 F1, F100 & Larger F-Series Trucks 18 05-30-2014 12:16 AM
Brakes JBronco 1978 - 1996 Big Bronco 2 11-17-2001 06:23 AM
Search this Thread:
Advanced Search
Posting Rules
You may not post new threads
You may not post replies
You may not post attachments
You may not edit your posts
BB code is On
Smilies are On
[IMG] code is On
HTML code is Off
Trackbacks are Off
Pingbacks are Off
Refbacks are Off
Forum Jump
