212 code, but no TFI module? Does a 7.5L have a TFI? - Ford Truck Enthusiasts Forums
Old 06-18-2014, 02:30 AM
7.5GasHog 7.5GasHog is offline
7.5GasHog is starting off with a positive reputation.
I guess I posted in the wrong forum, so this is kind of a re-post since I didn't get any replies.
So I had a check engine light and 2 codes. First was a 332 code, and I fixed that with a new EGR valve. The light was reset and does not come on but when I check the codes I still have a 212 code. So I figured someone had accidentally put a grey TFI module, when I needed black or vice versa. This is an E350 7.5L 1994, and when I pulled off the air cleaner box to get a look at the distributer, it has the flat part where the TFI mounts, but no TFI.
so 2 questions,
Were the 7.5L's made without TFI's?
I feel as though the code has been there all the time, I do not have any driveability issues, and the check engine light is no longer on, so does this really need to be fixed?
Old 06-19-2014, 06:30 PM
DIYiT's Avatar
DIYiT DIYiT is offline
DIYiT has a good reputation on FTE.DIYiT has a good reputation on FTE.
Nope. All of the EFI 460s have a TFI module. I think it switched with the body style in 92, but the later trucks are mounted on the driver's side fender on a heat sink. Look right below the hood spring. Check the functionality of the PIP sensor while you're at it. I don't remember if I had the same 212 code, but I had a code pointing to the TFI module as well and it turned out to be the PIP sensor instead.
56 F100 update-lexus/t bird suspension, and drive train done! cdl2374 1948 - 1956 F1, F100 & Larger F-Series Trucks 31 01-21-2017 10:39 PM
Dome Map light part # CharlyG Excursion - King of SUVs 6 11-28-2016 03:43 PM
Bought 17 F450 KR today, pick up Friday invstr55 2017 Super Duty 58 09-12-2016 08:11 PM
Can ANYONE please ID this color? rispony 1961 - 1966 F-100 & Larger F-Series Trucks 10 01-17-2016 04:30 PM
HELP! 212 code, but no TFI module? 7.5GasHog 1987 - 1996 F150 & Larger F-Series Trucks 10 06-19-2014 10:42 PM
Search this Thread:
Advanced Search
Posting Rules
You may not post new threads
You may not post replies
You may not post attachments
You may not edit your posts
BB code is On
Smilies are On
[IMG] code is On
HTML code is Off
Trackbacks are Off
Pingbacks are Off
Refbacks are Off
Forum Jump
