Weird turbo sound while towing - Ford Truck Enthusiasts Forums
1999 - 2003 7.3L Power Stroke Diesel SPONSORED BY:
Old 06-18-2014, 01:31 AM
90pioneer 90pioneer is offline
90pioneer is starting off with a positive reputation.
I towed a 12' enclosed trailer today 400 miles.
DP Tuner, and started off using 80 tow tune. Truck was sluggish. Switched to 80e and ran much better.
When making 12 to 18 pounds of boost the turvo starts making a very strange noise. Almost like a belt squeel or blow off valve noise. Its like a ch ch ch ch ch ch sound.
Goes away if more than 20lbs or under 12lbs of boost is being made.
Happens most prominently when in over drive. If the rpms go up over 2k it settles down.
Trailer and load weighs about 4500lbs I would guess.
Have towed heavier weights before and have not heard this sound before. Have 400 more miles to go tomorrow.
Old 06-18-2014, 02:19 AM
jps47's Avatar
jps47 jps47 is offline
jps47 is starting off with a positive reputation.
That sounds like turbo surge
Old 06-18-2014, 10:15 AM
Robert6401's Avatar
Robert6401 Robert6401 is offline
Robert6401 is a name known to allRobert6401 is a name known to allRobert6401 is a name known to allRobert6401 is a name known to allRobert6401 is a name known to allRobert6401 is a name known to all
Definitely sounds like turbo surge. You need to either downshift, slow down, or speed up - whatever it takes to avoid the surge because it will eventually kill your turbo.
Old 06-18-2014, 11:11 AM
Ford79's Avatar
Ford79 Ford79 is offline
Ford79 is a splendid one to beholdFord79 is a splendid one to beholdFord79 is a splendid one to beholdFord79 is a splendid one to beholdFord79 is a splendid one to beholdFord79 is a splendid one to beholdFord79 is a splendid one to beholdFord79 is a splendid one to behold
Turbo surge, most definitely.
Mine does the same thing. Anything over 12lbs boost under 2000 rpm it will surge bad.
I have an ATS ported housing to cure it, just have to install it.
New BlackVue DR650s and DR450/DR430 Series on Sale DashcamAndrew Vendor Specials, Discounts, Product Announcements & Group Buys 0 08-09-2016 01:45 PM
Drone from my 6.0 ch1k3n123 1999 to 2016 Super Duty 8 07-05-2016 08:05 PM
Transmission fluid for HEF CH 28385 Jonesy0027 1961 - 1966 F-100 & Larger F-Series Trucks 8 02-11-2015 10:42 PM
RV Compartment Keys and locks (exterior) BWAA-HA-HA! What a joke... Greywolf Other; Brakes, Electrical, Hitches, Weight Distribution & CDL Discussion 65 01-29-2012 02:31 PM
"Choo choo" sound from under the hood papadelogan 1999 - 2003 7.3L Power Stroke Diesel 21 05-10-2008 09:26 PM
Search this Thread:
Advanced Search
Posting Rules
You may not post new threads
You may not post replies
You may not post attachments
You may not edit your posts
BB code is On
Smilies are On
[IMG] code is On
HTML code is Off
Trackbacks are On
Pingbacks are On
Refbacks are On
Forum Jump
