stubborn 97 - Ford Truck Enthusiasts Forums
stubborn 97
Old 06-17-2014, 06:55 PM
Stroked 89 CA Stroked 89 CA is offline
Stroked 89 CA is starting off with a positive reputation.
stubborn 97
hopefully i can get some help here
truck is back on the grind of not starting , been an on going problem , truck starts when it wants to , whether its first start of the day , or after it just drove 100 miles , some days it fires right up and other it keeps cranking with no start , some days when it does start , even at operating temps when i shut it off , let it sit for a minute and it wont start back up just keeps cranking and cranking , im lucky ounce in a while it barley catches and fires , only way to get it to start is with a pinch of ether , i know my gp system is not working properly , but at these temps there not needed anyways , was recently at a local diesel shop and the ford dealer , between the two they told me it has good compression , good fuel pressure and passes a buzz test , dealer said the injectors could be binding up? truck does not miss a beat when running , no cel , everything works as it should , wts light all that stuff works , its got a new motorcraft cps , still wont start with the <acronym title="Injector Pressure Control">icp</acronym> unplugged , just throws a cel , i don't have a way to watch <acronym title="Injection Pressure Regulator">ipr</acronym> cycle and the tin nut is tight ,
codes its throwing are
p0113 - intake air temp circ low input
p0603 - internal ctrl mod KAM error
p0478 - exhaust press ctrl valve high input
p0470 - exhaust back pres sens circ error
- video of what it does
Old 06-17-2014, 07:42 PM
96ford250 96ford250 is offline
96ford250 is starting off with a positive reputation.
Sounds like your EBPV is stuck/sticking shut for starters the other codes I'm not so sure.
Old 06-17-2014, 08:07 PM
oldbird1965's Avatar
oldbird1965 oldbird1965 is offline
oldbird1965 is a splendid one to beholdoldbird1965 is a splendid one to beholdoldbird1965 is a splendid one to beholdoldbird1965 is a splendid one to beholdoldbird1965 is a splendid one to beholdoldbird1965 is a splendid one to beholdoldbird1965 is a splendid one to behold
My guess its your IPR getting old and sticking.
Old 06-22-2014, 11:15 PM
pretty sure my ebpv is open , its unhooked anyways , i am leaning towards the ipr also but i need to get it on a scanner to check duty cycle
anybody else?
1211 and 1212 codes countrycar 1999 - 2003 7.3L Power Stroke Diesel 8 11-21-2012 07:16 PM
engine miss and kill when warm. p1280, p1211 cyco 1999 - 2003 7.3L Power Stroke Diesel 3 09-24-2012 09:53 AM
Need Help Pleasee! stroken 1999 - 2003 7.3L Power Stroke Diesel 68 08-10-2010 10:50 PM
EXTREMELY rough running after startup, but cleared up? WTF??? strokin'_tatsch 1994.5 - 1997 7.3L Power Stroke Diesel 27 04-03-2010 06:39 AM
OBS Upgrades versus MPG aaron ford 1994.5 - 1997 7.3L Power Stroke Diesel 3 02-22-2009 10:32 AM
Search this Thread:
Advanced Search
Posting Rules
You may not post new threads
You may not post replies
You may not post attachments
You may not edit your posts
BB code is On
Smilies are On
[IMG] code is On
HTML code is Off
Trackbacks are Off
Pingbacks are Off
Refbacks are Off
Forum Jump
  • Ask a Question
    Get answers from community experts
What's your question?
Send
