7.3 IDI IP timing
7.3 IDI IP timing
Tried the search box thing but I can't seem to find any info, Anyway had some IP work done on my truck, there is no marks to line up on the IP or the housing, I scribed a line across the IP and housing before i removed the pump, when it came back from the shop they had cleaned my mark off the IP, tomorrow I am borrowing one of them adapters so I can use a gas motor timing light, what should it be set at? I seen somewhere 8.5BTDC at 2000rpm, is that correct?
on
IDI Dynamic Timing
may want to jump to;
https://www.ford-trucks.com/forums/3...l#post12805393
actually,it sounds like you may not have found the section devoted just to the international navistar 6.9l/7.3l idi diesels yet.
here it is.you'll find all kinds of good stuff about maintaining the old school diesels here:
https://www.ford-trucks.com/forums/forum117/
ford7.3l
05-15-2014 08:33 AM
