Go Back   Ford Truck Enthusiasts Forums > Diesel > Bio-diesel, Propane & Alternative Diesel Engine Fuels
Sign in using an external account
Register Forgot Password?
Register - Join us, its Free! Albums FAQ Members Tech Guides Search Today's Posts Mark Forums Read VendorsUsed CarsGarage
Welcome to Ford Truck Enthusiasts Forums
Bio-diesel, Propane & Alternative Diesel Engine Fuels SPONSORED BY:
  #1 (permalink)
Old 07-08-2003, 06:52 PM
Phreetogo Phreetogo is offline
Garage is empty, add now
Phreetogo is starting off with a positive reputation.
Question Veggy Oil Conversion Question
I recently got my truck up and running on Veggy Oil again. I had to rearrange things a bit and was wondering if anyone had any insight as to how this might affect my IP or other things. Under the normal set fuel goes from the tank to the lift pump to the filter and then to the IP. I now have it set up in this order. The tank to the filter to the lift pump to the IP inorder to incorporate two filters one for the veggy and one for the diesel without mixing the fuels too much. Any idea if this strains the lift pump or injection pump? Any alternatives to this idea if it does? thanks a lot for all your help. John
  #2 (permalink)
Old 07-11-2003, 11:35 PM
argve argve is offline
argve is starting off with a positive reputation.
Fluid pumps like to push not pull. So with that in mind, the best case is the pump before the filters.
The veggie oil should actually be better for the IJ pump, since it will lube the living snot out it. I would almost bet that you will get longer life out of the pump and injectors.
__________________
Travis
Enterprise. 1991 F350 CC DRW. 7.3 IDI, E4OD, Banks Turbo. - Many Mods
http://mywebpages.comcast.net/argve1/Enterprise.html
  #3 (permalink)
Old 07-14-2003, 01:25 PM
BlockBore BlockBore is offline
BlockBore is starting off with a positive reputation.
Phreetogo,
Where are you getting your veggy oil? I am looking to start running my truck on veggy oil but I have not been able to find a good CHEAP source of veggy oil. If you have any suggestions I would greatly appreciate it.
  #4 (permalink)
Old 07-17-2003, 06:59 PM
I get my oil by asking restraunt owners if I can pump their old grease out of their barrels. They usually don't mind if you don't make a mess. They usually have to pay to have their oil hauled away so it is good for both of us. Check out this link there is lots of good info if you are getting into this. Feel free to ask me any questions and I will do my best to answer them. Good luck, John
http://biodiesel.infopop.cc/6/ubb.x?...51&f=898605551
  #5 (permalink)
Old 07-21-2003, 03:59 PM
ctbiodzl ctbiodzl is offline
ctbiodzl is starting off with a positive reputation.
You need to heat the WVO too.
See posts by danalinscott for info on 6.9/7.3 WVO conversions
__________________
103K miles on biodiesel and WVO in VW TDI.
12K miles on biodiesel and WVO in a '92 F-250 n/a 7.3L diesel.
Tags
11, case, club, conversion, oil, pengine, truck, veggy, vilen
Search this Thread:
Advanced Search
Posting Rules
You may not post new threads
You may not post replies
You may not post attachments
You may not edit your posts
BB code is On
Smilies are On
[IMG] code is On
HTML code is On
Trackbacks are On
Pingbacks are On
Refbacks are On
Forum Jump
Powered by vBulletin® Version 3.7.5
Copyright ©2000 - 2013, Jelsoft Enterprises Ltd.
SEO by vBSEO 3.5.2 ©2010, Crawlability, Inc.
vbulletin Admin Backup
