Noob Fuel Question - Page 2 - Ford Truck Enthusiasts Forums
1994.5 - 1997 7.3L Power Stroke Diesel SPONSORED BY:
Noob Fuel Question
Old 06-20-2014, 11:37 AM
IDMooseMan's Avatar
IDMooseMan IDMooseMan is offline
IDMooseMan has a great reputation on FTE.IDMooseMan has a great reputation on FTE.IDMooseMan has a great reputation on FTE.IDMooseMan has a great reputation on FTE.IDMooseMan has a great reputation on FTE.
This is what you want to prepare for your future exhaust upgrades:
Click the link below to see my NAPA 6637 air filter and 41632 (blue pipe) exhaust elbow on my truck.
6637 Mod 1 by IDMooseMan - Ford-Trucks
I painted the pipe, but that was a personal choice.
Old 06-20-2014, 01:02 PM
cowmilker08's Avatar
cowmilker08 cowmilker08 is online now
cowmilker08 has a good reputation on FTE.cowmilker08 has a good reputation on FTE.cowmilker08 has a good reputation on FTE.
Whether you get the NAPA or the Donaldson filter, make sure it has the mesh on the inside of the filter to prevent it from collapsing.
Another option is the Amsoil filters you see in my signature. I've never ran a 6637, but I love the filters I use.
You definitely want to spend the money on a decent downpipe. They are pretty cheap. Also, while you're doing it, look into gutting the exhaust back pressure valve (EBPV). Its not something everyone wants to do, but I don't miss mine even a little.
Old 06-21-2014, 03:24 PM
Leatherneck007's Avatar
Leatherneck007 Leatherneck007 is offline
Leatherneck007 is starting off with a positive reputation.
exhaust
Mine is already straight piped turbo back. But my exhaust is 3 inches, is that stock?. I know I need to get a bigger one. What size downpipe should or can I gwt without cutting anything? Also where is the EBPV?
Old 06-21-2014, 03:42 PM
Where did you get the pipe? And isnt that filter more prone to get dirt in the air versus the stock one? I drive 10 miles of gravel just to get to the highway from my house. So is this filter ok for that?
Old 06-21-2014, 06:00 PM
IDMooseMan's Avatar
The air filter and pipe are both from NAPA. I've had no problems with this filter. This is the same one that some bigger trucks use, as well as some tractors and other industrial / heavy-duty applications.
I've driven on gravel and dirt roads, through heavy rain and snow, through "puddles" and have had no problems. I recently replaced my filter after driving for about three years on the previous one. I will not go back to the OEM setup and I have no interest in using a K&N or other setup. This setup works fantastic.
Old 06-21-2014, 09:28 PM
Ok thanks. What is the pipe from napa called? Does it have a special name?
Old 06-21-2014, 10:14 PM
dragoon1101 dragoon1101 is offline
dragoon1101 is starting off with a positive reputation.
i believe all you need is the number and they will get you set up its 41632 and it looks to be about 3.5in ID if im not mistaken?
Old 06-21-2014, 11:24 PM
Ok, my question from before, Mine is already straight piped turbo back. But my exhaust is 3 inches, is that stock?. I know I need to get a bigger one. What size downpipe should or can I get without cutting anything? Also where is the EBPV?
Old 06-21-2014, 11:29 PM
EBPV is on the turbo exhaust side where the down pipe is attached to the turbo its the 2 inch piece that protrudes off the turbo and has a open/close valve inside it if u don't want to use it u can just unplug it (turbo intake side bottom) or u can do the exhaust break mod !
and i think that the stock pipes are 2.5inch not totally sure here tho.... and from what i have read 3 inch is as big as u can go without modding the
side wall/firewall.... but it is still a bear to get it in without pulling the EBPV off the turbo
Old 06-22-2014, 12:12 AM
how much will a decent down pipe cost?? and what is the purpose of a EBPV?
Old 06-22-2014, 12:18 AM
the EBPV is used by the engine to quicken the warming of the motor (cold/winter) and opens back up when motor reaches a warm enough temp on warm days like now itll close for a very short time then open back up its not really needed and alot of people "delete" it to know how to do this just search EBPV delete on YouTube!
Old 06-22-2014, 12:20 AM
Diamond Eye | 122004 | Downpipe 3" AL: 1994-1997.5 Ford 7.3L Powerstroke F250/f350
this is what i found with a quick google search this one looks to be a 2 piece so it'll be an easier install shouldn't have to remove anything save for the old downpipe!!!
  #28
Old 06-22-2014, 01:32 AM
Correct info on the EBPV. I've had mine deleted for 5 years and don't miss it. This winter when it was -20, the truck had no problem staying at operating temp.
The stock downpipe is an obround shape. I'm not sure of the size. The rest of the stock exhaust is 3.5 in. You definitely want a 2 piece 3 in downpipe for easy install. Its adequate for most people's horsepower. I recommend diamond eye. You should be able to find them for less than $150.
  #29
Old 06-22-2014, 01:35 AM
thanks Cowmilker08
  #30
Old 06-22-2014, 01:55 AM
No problem. Glad I could help.
If you are trying to add just a little power and don't want to chip it, you could look into the 1.0 turbine housing or some of the resistor mods. That would save you some money.
Missing or stuttering under load. iverger 1994.5 - 1997 7.3L Power Stroke Diesel 1 11-22-2015 04:59 PM
Smell burning oil under load iverger 1994.5 - 1997 7.3L Power Stroke Diesel 7 04-14-2015 05:01 PM
Dude, where's my tuning? cleatus12r 1999 - 2003 7.3L Power Stroke Diesel 78 12-10-2013 06:29 PM
stumble at 2500 rpm and smoke stevetford 1994.5 - 1997 7.3L Power Stroke Diesel 17 05-02-2010 11:13 PM
Pulled the trigger on a Diablo Chip! DCClark 1999 - 2003 7.3L Power Stroke Diesel 22 06-20-2003 07:09 PM
Search this Thread:
Advanced Search
Posting Rules
You may not post new threads
You may not post replies
You may not post attachments
You may not edit your posts
BB code is On
Smilies are On
[IMG] code is On
HTML code is Off
Trackbacks are On
Pingbacks are On
Refbacks are On
Forum Jump
