New 6.2 Tow Questions - Page 2 - Ford Truck Enthusiasts Forums
6.2L V8 Discuss the 6.2L V8
Old 06-20-2014, 01:57 PM
mackintire mackintire is offline
mackintire is starting off with a positive reputation.
The area under the torque curve is greater at low RPMs with the 6.8 liter V10 than the 6.2 liter V8.
Personally properly geared the 6.2 should be able to pull the same amount of weight, but it may not inspire the same level of confidence or attain the equal fuel economy. (Hard to believe, I know)
Once DI is added onto the 6.2 liter the assumption is that the 6.2 will have enough power to be a better performer overall enough to warrant phasing in the 6.2 to replace the 6.8 without annoying the commercial buyers who tend to go with what they know "just works".
Old 07-05-2014, 10:18 AM
Buckholz Buckholz is offline
Buckholz is starting off with a positive reputation.
I have a 2011 F350 4x4 6.2L LB CC with 3.73. Coming up on 100,000 miles. Have owned 4 diesels prior. Tow a variety of trailers up to 10,000 and also have a slide in Camper. Live at 7,000' elevation. Tow up to 80mph at times, for extended periods of time.
No regrets going gas, will not buy a diesel again. While I spend a little more in fuel costs, love the dependability and simplicity and low costs of my 6.2.
At elevation, and when towing, had wished I had gotten the 4.30 gears. Probably the only thing I would do differently next time.
Once again, love the 6.2....
Old 07-05-2014, 06:01 PM
gasman6674's Avatar
gasman6674 gasman6674 is offline
gasman6674 is gaining momentum as a positive member of FTE.
Thanks for all the input. I went ahead and ordered a F350 CCLB RWD with 6.2 and 4.30 rear axle. I think it will do great for me and My occasional towing. Now if it would just get here. Again thanks to all.
Old 09-04-2015, 10:30 AM
SWV10's Avatar
SWV10 SWV10 is offline
SWV10 is starting off with a positive reputation.
Quote:
Now that you have your 2015 F350 6.2L 4.30's for awhile, do you feel you made the right decision with this gasser?
Old 09-04-2015, 10:54 AM
gasman6674's Avatar
Yes, I have a little over 15,000 in a year on the truck right now with approx 900 of that towing.
I didn't start towing till after 5000 per ford so for me 98-99% of the miles is daily commute(50 miles a day combo city / interstate). Truck has done every thing I have ask it to do with no issues and done it well. Total avg mpg since I have owned it is 10.5, the avg on the lie o meter is 11.5. I usually get 8-9 towing. I have run E 85 in it but the mpg drop is not worth the difference in fuel cost.
Old 09-04-2015, 02:33 PM
SWV10's Avatar
Thanks, good info.
I too tried the E85 in my F150, good power as gas but the mpg was terrible, never again and at only .50 cheaper than the 88 I use (No 87 here), it cost me more $ with the E85.
28,700 lbs GCWR for 6.2L F250 SRW w/4:30? Louie-T 2017 Super Duty 8 09-18-2016 08:01 PM
Doing a gear swap on 2011 f350 6.2 airm4n 1999 to 2016 Super Duty 20 10-26-2015 10:49 PM
2014/2015 F350 6.2L TOWING gasman6674 1999 to 2016 Super Duty 9 06-12-2014 04:33 PM
F-250 6.2 / Fifth Wheel Toy Hauler Size trav99ss Toy Hauler Towing; Fifth Wheel & Bumper Pull 15 11-05-2012 11:16 PM
5th Wheel Towing Weight Limitations rflamm 1999 to 2016 Super Duty 8 10-24-2002 07:41 PM
Tags
towingcapabilities
Search this Thread:
Advanced Search
Posting Rules
You may not post new threads
You may not post replies
You may not post attachments
You may not edit your posts
BB code is On
Smilies are On
[IMG] code is On
HTML code is Off
Trackbacks are On
Pingbacks are On
Refbacks are On
Forum Jump
