Your Favorite Code Scanner
Hey all, Yes I am new here. And I have already found tons of useful Info for my project, which is a 91 F250 extended cab 4x4 that was an Arizona left in the yard truck (12 years) with all the usual fuel, dry seals, and dead rubber issues, but that is for another thread. Instead, I wanted to ask, since I don't as yet own one, what is your favorite code scanner for an ODB1 truck like this?
Oh and yes I checked the tech sticky and it had a link but it was a deadend. Besides, this way the answerers are more current. <o></o
<o</o
<oThanks in advance.</o
<o</o
I have this one:
Innova Electronics 3145 - Digital Code Reader | O'Reilly Auto Parts
Works great. Comes with a detailed book to decipher the codes including instructions. Works for various Ford vehicles 1981-1996
Where in Az are you?
on
Innova/Equus 3145 is the hands down favorite in this forum
Amazon.com: INNOVA 3145 Ford Digital Code Reader: Automotive
Trav
I have this one:
Not sure if a Scanner will do any more than read codes on a 1991 depending on engine size and GVW as far as a Scanner goes. I like the Actron Scanner CP9190-9185. I have the CP9190 and it works great for scanning the data wires in the self-test plug for my 1994 & 1995 Fords.
joegeds,
It also works great on the OBD-II systems.
Here is an example out put from my CP9190 reading data:
I will take what I can get... and I am used to a scanner for the OBDII stuff like my 2001 Jeep TJ, but I am completly ignorant as to the capabilities of a ODBI system. I have and older Proscan for my ODBII cars and trucks and I sure like to see real time data.... Had a loose connection on an injector once that I dont think I could have found any other way, but if read is all I can do I will take that. I am DONE with the flasing light method.
As I said it depends on your engine size GVW as to it you can read data or just get codes.
You did not say what your engine size or GVW was.
By the way you do not need a code reader to get the codes on the Jeep. You just turn the key on and off three times and the codes will be displayed on the Odometer LCD.
I know this works on my 1999 Jeep GC.
