How do I identify an 8BA block? - Ford Truck Enthusiasts Forums
Old 06-16-2014, 10:43 PM
D Sokol's Avatar
D Sokol D Sokol is offline
D Sokol is starting off with a positive reputation.
My engine rebuilder just called and said my block for my '50 F-1 is cracked beyond repair. The heads, water pumps, intake etc are good.
I am not the sharpest knife in the drawer, so I could use some help.
How could I identify a bare block as being an appropriate 8BA for for my '50?
Are there stamped/cast numbers? Length? Smell?
I may have a line on a couple blocks here in the phoenix area, but I want to make sure I am looking at something that will be useful to me. This person wants around $250 for one. Good price?
Help!
Thanks a whole bunch in advance.
Dan Sokol
Old 06-16-2014, 10:54 PM
ALBUQ F-1's Avatar
ALBUQ F-1 ALBUQ F-1 is online now
postin' fool
ALBUQ F-1 has a spectacular reputation.ALBUQ F-1 has a spectacular reputation.ALBUQ F-1 has a spectacular reputation.ALBUQ F-1 has a spectacular reputation.ALBUQ F-1 has a spectacular reputation.ALBUQ F-1 has a spectacular reputation.ALBUQ F-1 has a spectacular reputation.ALBUQ F-1 has a spectacular reputation.ALBUQ F-1 has a spectacular reputation.ALBUQ F-1 has a spectacular reputation.ALBUQ F-1 has a spectacular reputation.
Ideally, get an whole engine that you can see running in a car/truck, that the seller is going to yank. It doesn't need to be in great shape but needs to fire on all cylinders, not bubble into the cooling system, etc. Price according to how well it runs. For instance, this seems like a good deal; late model flathead, if it is in good running condition and doesn't need a rebuild, it's a good savings: flathead ford V8
Deals like this come up frequently, just be patient. I do have a spare block that has been magnafluxed and had some cracks fixed. I get over to Glendale a couple times a year, too, to visit my son (not this time of year!!)
Old 06-16-2014, 11:17 PM
D Sokol's Avatar
Mine was running when I decided to pull it and rebuild "because I don't know if it ever was".
Guess I'm glad I found out now, but it has made me a little gun shy.
DjS
Old 06-16-2014, 11:18 PM
D Sokol's Avatar
Oops.
sorry.
DjS
Old 06-17-2014, 12:36 AM
tinman52's Avatar
tinman52 tinman52 is offline
Welder User
tinman52 has a spectacular reputation.tinman52 has a spectacular reputation.tinman52 has a spectacular reputation.tinman52 has a spectacular reputation.tinman52 has a spectacular reputation.tinman52 has a spectacular reputation.tinman52 has a spectacular reputation.tinman52 has a spectacular reputation.tinman52 has a spectacular reputation.tinman52 has a spectacular reputation.tinman52 has a spectacular reputation.
Easiest way to tell them apart is by the back of the block. Early engines had the bell housing cast onto the block, late (8ba) engines do not.
If you buy a bare block, make sure the main bearing caps are with it. I consider all "complete" flatheads to be cores(not worth much) unless I can see/hear them run or can pull the heads to inspect for cracks.....
How difficult to set door glass? D Sokol 1948 - 1956 F1, F100 & Larger F-Series Trucks 3 12-11-2016 10:38 AM
Oil filter lines/pressure sensor 239 D Sokol 1948 - 1956 F1, F100 & Larger F-Series Trucks 19 03-13-2016 03:21 PM
6v bulb types and suppliers D Sokol 1948 - 1956 F1, F100 & Larger F-Series Trucks 2 07-05-2015 01:48 AM
'50 OEM Bed Assembly D Sokol 1948 - 1956 F1, F100 & Larger F-Series Trucks 10 01-25-2015 10:19 AM
OE wiring a '50 F1 D Sokol 1948 - 1956 F1, F100 & Larger F-Series Trucks 24 06-07-2014 04:23 PM
Search this Thread:
Advanced Search
Posting Rules
You may not post new threads
You may not post replies
You may not post attachments
You may not edit your posts
BB code is On
Smilies are On
[IMG] code is On
HTML code is Off
Trackbacks are Off
Pingbacks are Off
Refbacks are Off
Forum Jump
