IH uppies & RR wheel - wierd noise - Ford Truck Enthusiasts Forums
Old 06-16-2014, 10:37 PM
hydro man 17 hydro man 17 is offline
hydro man 17 is gaining momentum as a positive member of FTE.hydro man 17 is gaining momentum as a positive member of FTE.
Got the IH bellowed ceramic up pipes and Clay's 6x6 billet wheel installed and all is good except for an odd noise a couple of times. Boost pressure seems to be lower than it used to be at a given "no load condition" ( 2.5 to 5 psi ) but spools to 20+ PSI almost instantly when on it. Only issue was twice today when accelerating from a full stop I had noticed a noise that sounded like a loud clacking like lifters without sufficient oil pressure for a lack of a better description. Oil level and pressure is normal for that issue. Let of and all went normal and all normal on the way home later on.
Will waste gate fluctuating or boost leak make this happen? I did notice a slight whisteling sound when letting off the throttle but assumed it was the new wheel, but will the waste gate do this as well? The turbo was totally "reconditioned", hot tanked, bead blasted and all but don't know if the waste gate could be affected.
Old 06-17-2014, 06:31 AM
Tugly's Avatar
Tugly Tugly is offline
I'm a cautionary tale.
Tugly has a superb reputationTugly has a superb reputationTugly has a superb reputationTugly has a superb reputationTugly has a superb reputationTugly has a superb reputationTugly has a superb reputationTugly has a superb reputationTugly has a superb reputationTugly has a superb reputationTugly has a superb reputation
Exhaust leaks are loud, and they drown out much of the rest of the truck. Every time I tame the loudest part of Stinky, I find the next-loudest part. You might be hearing your injector cackle - have you done the fuel mods? Another point - try your same run in stock tune. I was able to get as high as 22 PSI with stock tune, wastegate line capped, and big air in/out.
Old 06-17-2014, 11:27 AM
Thanks for the reply Rich.
Well I don't think that I had an exhaust leak before the new up pipes - it was a preventetive maintenance sort of thing. Thinking back I had the same noise about a year ago and I think it threw some sort of injector code but I don't recall at this point. Never came back, but I don't know if this is the same. No CEL but I will check with AE
Old 06-19-2014, 12:34 AM
update
No codes found and last trip to town and back no hiccups with WOT ( lots of cops here). Very happy with the new wheel from Clay - saw 23 PSI peak, gets there real fast. Mostly stock stuff except per SIG.
This was in 60 E on DP
Help: Extremely low fuel pressure at WOT - 20 PSI exbxtoy 1999 - 2003 7.3L Power Stroke Diesel 62 02-03-2017 10:29 AM
Waste Gate Operation tjmike 1999 - 2003 7.3L Power Stroke Diesel 8 11-06-2015 02:21 PM
Purge noise and Hiss under hard acceleration luckydevil 1999 - 2003 7.3L Power Stroke Diesel 10 02-25-2012 07:51 AM
waste gate adjustment gumper 123 Pre-Power Stroke Diesel (7.3L IDI & 6.9L) 6 07-31-2011 11:06 PM
Thank you Clay! No new parts but LOTS more power! thordehr 1999 - 2003 7.3L Power Stroke Diesel 9 01-02-2011 05:37 PM
Search this Thread:
Advanced Search
Posting Rules
You may not post new threads
You may not post replies
You may not post attachments
You may not edit your posts
BB code is On
Smilies are On
[IMG] code is On
HTML code is Off
Trackbacks are Off
Pingbacks are Off
Refbacks are Off
Forum Jump
