Vent window question 60 custom cab
Scratching my head here how rare are chrome/stainless vent window frames my truck had one on the driver side and regular black on pass side but while doing the paint & body work it looks as the pass side was replaced some time long ago as it came appart much easer and all the hardware looks new both doors appear orriginal as I got the truck from the orriginal owners grandson and the paint was same color undrerneath two color change repaints the truck is a factory big window custom cab I would like to get a shinney one for the pass side.Whats up guys
I have a '57 custom cab and I can't find references for the stainless steel vent window frames. I will say when I disassembled mine, and removed the paint, I found a good deal of rust in the channel near the pivot pin and that was also badly rusted.
I tried sourcing new stainless frames without success. Then I tried to make them just look better. First I tried to paint them black... but it looked bad. Then, I started sanding them down up to 400 grit, then polished them up to a mirror like shine. They look great!
I'm trying to see if they truly are stainless by seeing if they get some surface rust. I tried using the magnet trick, but then found out some types of stainless fail the magnet trick. It's really hard to tell what they're made of.
It's been almost 3 weeks of a wet NJ spring... haven't found rust yet. Time will tell. Are you sure it's a replacement and not just given a quickie spray job?
It's been almost 3 weeks in a wet NJ spring... haven't found rust yet. Time will tell. Are you sure it's a replacement and not just given a quickie spray job?
Stainless (rustless) steel vent frames were only available for 1957/58 Custom Cabs, all other 1957/60's were only available with painted vent frames.
Notice in the pic that Ford only sold the vent frame (21406) with the glass, only the glass (21412) was available by itself.
zora1800
05-05-2005 09:47 AM
