unpinning and repinning a plug on the TFI module
The plug that plugs into the TFI module has broken tabs and has a tendency to fall out of the TFI. How do you remove the little red retainer that holds the wires into the plug so that I can replace the plug and repin all the wires? 90 Ranger with 2.9/auto
http://i1162.photobucket.com/albums/...ps90d99389.jpg
http://i1162.photobucket.com/albums/...ps558123e5.jpg
http://i1162.photobucket.com/albums/...psf4e09b1c.jpg
How do I remove the wires from the plug? I am using this plug to replace the damaged plug on the truck
Look up in this end.
Are there little tangs for each metal terminal that you can depress with a very small screwdriver to release each metal terminal?
