#10 misfire? - Ford Truck Enthusiasts Forums
Excursion - King of SUVs 2000 - 2005 Ford Excursion SPONSORED BY:
#10 misfire?
Old 06-16-2014, 07:11 PM
BigBlkEX's Avatar
BigBlkEX BigBlkEX is offline
BigBlkEX is gaining momentum as a positive member of FTE.
#10 misfire?
So I pluged up my obd2 reader yesterday bc I eas board and bam I have a misfire on #10 wounder how long its bsen that way not sure :-\... bought a new Ignition coil swaped it out let it run a little while and no codes came up so drove around the neighborhood and pluged it in again and bam again misfire #10 any thoughts what it could be going to change the 10 sparks tomorrow hoping thats what it is.
Old 06-16-2014, 07:26 PM
EXv10 EXv10 is offline
EXv10 has a superb reputationEXv10 has a superb reputationEXv10 has a superb reputationEXv10 has a superb reputationEXv10 has a superb reputationEXv10 has a superb reputationEXv10 has a superb reputationEXv10 has a superb reputationEXv10 has a superb reputationEXv10 has a superb reputationEXv10 has a superb reputation
Quote:
Probably the wet boot.
Old 06-16-2014, 08:02 PM
Toreador_Diesel's Avatar
Toreador_Diesel Toreador_Diesel is offline
Toreador_Diesel has a superb reputationToreador_Diesel has a superb reputationToreador_Diesel has a superb reputationToreador_Diesel has a superb reputationToreador_Diesel has a superb reputationToreador_Diesel has a superb reputationToreador_Diesel has a superb reputationToreador_Diesel has a superb reputationToreador_Diesel has a superb reputationToreador_Diesel has a superb reputationToreador_Diesel has a superb reputation
Quote:
Brent, I belive you wrote a good write up on what the solution was.
Old 06-16-2014, 08:21 PM
Old 06-16-2014, 10:11 PM
Apocalypse's Avatar
Apocalypse Apocalypse is online now
Apocalypse has a superb reputationApocalypse has a superb reputationApocalypse has a superb reputationApocalypse has a superb reputationApocalypse has a superb reputationApocalypse has a superb reputationApocalypse has a superb reputationApocalypse has a superb reputationApocalypse has a superb reputationApocalypse has a superb reputationApocalypse has a superb reputation
I thought I had the same issue, but my #9 AND #10 were dead... Then I remembered I have the 5.4
Old 06-17-2014, 12:10 AM
BigBlkEX's Avatar
Quote:
Thanks for the advice but its bone dry. No water leaks from the seal on the crowl where the hood shuts. We haven't had any rain for about 2 weeks also. I switch the old one back on and drove about 20 miles let it sit for awhile and drove for another 20 miles or so. And I have no codes come up when I check. Weird something's up.
Old 06-17-2014, 08:27 AM
BassFantasizer's Avatar
BassFantasizer BassFantasizer is offline
Dirty Old Man in training
BassFantasizer has a superb reputationBassFantasizer has a superb reputationBassFantasizer has a superb reputationBassFantasizer has a superb reputationBassFantasizer has a superb reputationBassFantasizer has a superb reputationBassFantasizer has a superb reputationBassFantasizer has a superb reputationBassFantasizer has a superb reputationBassFantasizer has a superb reputationBassFantasizer has a superb reputation
I dropped a set of plugs in the Ex a couple of months ago and immediately wound up with a #10 misfire. The cylinder wasn't dead, just not "right".
It turned out that when I pulled the plug off of the #10 injector (to get my big old hands to #10 without breaking anything) the retaining clip on the plug broke. When I reconnected the plug, it appeared to be in place but it wasn't making a good enough connection to generate a consistent fuel flow and power.
The onboard electronics picked it up and signaled a #10 misfire.
It's an easy thing to check!
Old 06-18-2014, 02:12 AM
BigBlkEX's Avatar
Funny I replaced all my sparks today and I restarted it and it wasnt running right again. Played with all the boots a little wiggle here and there and then I noticed the plug to the ignition coil was cracked making a poor connection. Replaced it good to go. Thanks all for your advice.
Old 06-18-2014, 12:33 PM
Those boots need to be replaced at least every time you replace the plugs.
sensor questions wedge542 6.0L Power Stroke Diesel 15 04-04-2016 08:49 PM
Fuel Pressure Diagnostic After Injector Replacement. jchosler 1999 - 2003 7.3L Power Stroke Diesel 5 12-07-2015 12:19 PM
Continuing saga of the rough idle.... NICKSAN 1968-2013 Full Size Vans 26 10-18-2015 01:52 PM
Got'er Done p050 bohiaa 1999 to 2016 Super Duty 0 05-27-2014 08:57 PM
Ford Super Duty VS Honda Accord - Viva La Bam Johnboy_BoomerSooner General Automotive Discussion 16 06-10-2004 01:12 AM
Search this Thread:
Advanced Search
Posting Rules
You may not post new threads
You may not post replies
You may not post attachments
You may not edit your posts
BB code is On
Smilies are On
[IMG] code is On
HTML code is Off
Trackbacks are Off
Pingbacks are Off
Refbacks are Off
Forum Jump
