Plz need help with a 4.6 - Ford Truck Enthusiasts Forums
Old 06-16-2014, 02:23 PM
Bartramk Bartramk is offline
Bartramk is starting off with a positive reputation.
I have a 2001 f150 it stumbles on take off and in regular drive gear. I've changed spark plugs and all coils are working fine. I'm getting a couple of codes on the scanner one is p1408 EGR flow out of range. It has a brand new EGR valve on it. Secondly it's showing p1131 h025 bank 1 sensor indicates lean. I don't know what to do no cat codes or misfire codes what does all of this mean?
Old 07-25-2014, 12:44 PM
Coondawg Coondawg is offline
Coondawg is starting off with a positive reputation.
Try cleaning the throttle body and maf
sensor.
Old 08-12-2014, 02:18 PM
Driver Jim Driver Jim is offline
Driver Jim is starting off with a positive reputation.
For the EGR:
It's vacuum modulated, so I'd look at the tubing to make sure it seals properly/nothing was broken when the valve was changed. If the vacuum reaching the EGR is wrong, the valve won't open properly.
Actually, as I re-read your post I'd most definitely look at the vacuum modulator tubing as a leak will suck in air unaccounted for by the MAP/MAF, thus leaning the air/fuel mixture. Bank 1 is the one through four cylinders on the passenger side, which is where the tubing for the EGR vacuum originates.
What is P0404 - EGR Circuit Range/Performance? Carpenterw1 6.0L Power Stroke Diesel 2 01-23-2016 11:22 AM
No start with codes meetre 6.0L Power Stroke Diesel 11 02-23-2015 11:29 PM
99 E150 4.2 V6 EGR code TXE150 1968-2013 Full Size Vans 2 01-03-2015 07:10 PM
2002 Ford Ranger EGR Code - but no EGR? BigTexan Ranger & B-Series 9 06-06-2009 01:14 PM
2003 Expy with P0405 code Bedasi Expedition & Navigator 3 05-27-2007 02:39 PM
Search this Thread:
Advanced Search
Posting Rules
You may not post new threads
You may not post replies
You may not post attachments
You may not edit your posts
BB code is On
Smilies are On
[IMG] code is On
HTML code is Off
Trackbacks are On
Pingbacks are On
Refbacks are On
Forum Jump
