out of opitions on 4.6l
I have a 2000 Expedition 4.6l with 190000 miles in my shop for not running. I have got it to run, but it is missing on #2,5,6,7,8. checked the timing and correct, have fire on coils and power to injectors. Cats are not plugged up. I am out of options please help. compression test was 150,90,120,120,140,60,160,160/1-8 in order.
It can and it will. If the exhaust spring broke then the other cylinder's exhaust gets sucked into the intake leaning out the mixture. If the intake spring broke then the other cylinder's exhaust gets sucked into the intake leaning out the mixture. Regardless, you need to address the 2 cylinders with low compression first.
On the weak cylinders, reset for a leak down test with shop air regulated at 90 PSI. Take the oil cap off and listen for blowing air. Get the air intake tube out of the way and open the throttle butterfly, again listening for rushing air. Last, stick your head by the tail pipe. Also, take the radiator cap off and look for bubbling as this would point at a head gasket.
That compression is going SOMEWHERE. This style of blow-by test will narrow down your search to either a eroded valve face, valve, ring or gasket issue.
Rmc292
12-15-2013 04:18 PM
whybnormal
10-18-2007 07:58 AM
bigbeise
06-04-2006 03:30 PM
