f350 tailgate 2014 - Ford Truck Enthusiasts Forums
1999 to 2016 Super Duty 1999 to 2016 Ford F250, F350, F450 and F550 Super Duty with diesel V8 and gas V8 and V10 engines
f350 tailgate 2014
Old 06-16-2014, 12:44 PM
dg6490 dg6490 is offline
dg6490 is starting off with a positive reputation.
f350 tailgate 2014
Will a tailgate from any other models fit my f350 2014?
Old 06-16-2014, 01:06 PM
jpr38057 jpr38057 is offline
jpr38057 has a great reputation on FTE.jpr38057 has a great reputation on FTE.jpr38057 has a great reputation on FTE.jpr38057 has a great reputation on FTE.jpr38057 has a great reputation on FTE.jpr38057 has a great reputation on FTE.
Need to know a lot more information such as step, no step. Single or dual rear wheels. What trim level eg Platinum, king ranch etc.
Old 06-16-2014, 01:18 PM
xmontex4's Avatar
xmontex4 xmontex4 is offline
xmontex4 is a name known to allxmontex4 is a name known to allxmontex4 is a name known to allxmontex4 is a name known to allxmontex4 is a name known to allxmontex4 is a name known to all
All tailgates from 99-current should fit if you mean different model as in like an F150 tailgate they will not fit a super duty but pre99 all fseries gates are interchangeable except step sides of course.
-99-07 use the same hinges
-08+ can use the same hinges as 99-07 but the 08+ gates have a built in torsion bar which requires the newer hinges to work. The hinges are not expensive so its worth it IMO.
Old 06-17-2014, 09:39 PM
Quote:
The truck is a basic model crew cab no sidestep and it is not a dually. Its just a regular work truck.
Old 06-18-2014, 01:46 PM
They are the same back to 2008.
Old 06-19-2014, 03:54 PM
Psyclopse's Avatar
Psyclopse Psyclopse is offline
Psyclopse has a great reputation on FTE.Psyclopse has a great reputation on FTE.Psyclopse has a great reputation on FTE.Psyclopse has a great reputation on FTE.Psyclopse has a great reputation on FTE.
You can even go back as far as 99 with the appropriate hinges
Tailgate assist, how to remove tailgate coastaldc 1999 to 2016 Super Duty 14 01-18-2017 10:39 PM
2005 f350 bed change to a 2014 f350 bed justin414182 1999 to 2016 Super Duty 6 12-06-2015 06:51 PM
NEED QUICK ANSWER ! does 2014 tailgate fit a 02? rollin_coal 1999 to 2016 Super Duty 15 11-02-2014 11:31 PM
2009-2014 F150 tailgate NEW take off! rgs4x WTB - Parts & other 0 10-31-2014 03:07 PM
2014 F350 Tailgate Cables brian743 1999 to 2016 Super Duty 2 02-19-2014 04:53 PM
Search this Thread:
Advanced Search
Posting Rules
You may not post new threads
You may not post replies
You may not post attachments
You may not edit your posts
BB code is On
Smilies are On
[IMG] code is On
HTML code is Off
Trackbacks are Off
Pingbacks are Off
Refbacks are Off
Forum Jump
