1999 to 2016 Super Duty 1999 to 2016 Ford F250, F350, F450 and F550 Super Duty with diesel V8 and gas V8 and V10 engines
Cat back exhaust for 5.4- drone free recommendations?
Old 06-16-2014, 10:04 AM
zimm's Avatar
zimm
zimm is offline
I'm thinking about replacing my exhaust from the cats back because my heat shields are rusted and rattling on the exhaust tubes.
Dynomax makes a cheap cat back and Gibson makes a nicer stainless one. Or piece together a walker system, I do like their stainless "quietflo" mufflers. Any recommenadions? I tow a boat and I don't want any drone or resonation in the cab under load.
I had a magnaflow on my prior V8 4runner and it was terrible while towing, I had to replace it with a Walker quietflo- and that fixed that problem.
Old 06-16-2014, 01:32 PM
Dynomax Exhaust's Avatar
Dynomax Exhaust
Dynomax Exhaust is offline
PREMIUM SPONSOR
Talking
Check out one of our stainless steel VT muffler, it is a drone-free muffler.
DynoMax® VT® Mufflers - DynoMax® Performance Exhaust
Also our systems are on rebate until the end of June too.
Good luck!
__________________
Follow us on Facebook!
https://www.facebook.com/dynomaxexhaust
http://www.dynomax.com
Old 06-16-2014, 06:22 PM
dkf's Avatar
dkf
dkf is offline
I would cut the heat shields off. You don't need them anyway. The OE exhaust is pretty good on your year really. My 04' has been without heat shields for years now.
If you still want to go with a catback take a look at the Flowmaster Force II catback in 409 stainless. It routes in the stock location and the stainless version comes with much better quality hardware than the aluminized version. I have been running them for over 5 years now and I put one on my dads truck too. We both tow. The FM70BB2 is a pretty big muffler with quite a bit of capacity and anti drone chambers. It handles our V10s well which can sound more annoying than the 5.4l. Auto Anything usually has the best prices, I ordered all mine from there.
I believe part # 817422 fits your truck.
Flowmaster Cat Back Exhaust Systems - 760+ Reviews on Loud Flowmaster American Thunder, Force II, dBX & Pro Series Stainless Steel Dual Exhaust Kits
Old 06-16-2014, 07:01 PM
zimm's Avatar
zimm
zimm is offline
Thanks for the input. I'll cut the shield first, that flow master wouldn't replace the section of troubled pipe anyway. Might leave muffler stock. Like you said, it's a pretty high flow 3" system stock.
Old 06-17-2014, 07:28 PM
martdog420's Avatar
martdog420
martdog420 is offline
Trailering
My 06 f250 5.4 had a brutal buzzing vibrating that i thought was heat shields till i took them off and the noise was still there.. Turned out to be the baffles in the muffler fell apart.. everything looked great from the outside still, this was this spring 04/2014
Old 06-18-2014, 08:13 AM
bbender85's Avatar
bbender85
bbender85 is offline
i was going to reccomend leaving the adequate OE 3" system intact too. did that on my old 5.4 SD and just swapped the cat and muffler out for higher flowing magnaflow units, along with a 4" tip and it sounded pretty nice. had a very slight drone while towing my loaded down high-profile 24' toy hauler, but wasn't obnoxious or annyoing.
Old 06-19-2014, 06:53 PM
02TB250's Avatar
02TB250
02TB250 is offline
I would recommend this as well the 3" factory piping is sufficient with the resonator. Any small mufflers ( needing an extension pipe to fill the gap) are going to drone. My flowpath Mac muffler drones at 2000-2200rpm but it's rarely an issue and much better compared to other mufflers I've had/heard
Old 06-19-2014, 08:07 PM
dkf's Avatar
dkf
dkf is offline
His year truck may have a 3.5" tailpipe. The 6.8l of that year did.
dudewayne
12-18-2015 07:21 PM
hoytfan99
Modular V10 (6.8l)
07-30-2010 09:23 PM
SPELLY F150
07-14-2009 09:27 AM
seebeew
Exhaust Systems
10-02-2002 01:14 AM
Rockwell
Exhaust Systems
02-10-2002 09:47 AM
Quick Reply: Cat back exhaust for 5.4- drone free recommendations?
