Split vs Open plenum design - Ford Truck Enthusiasts Forums
Old 06-16-2014, 09:38 AM
Turbo Dog's Avatar
Turbo Dog Turbo Dog is online now
Turbo Dog has a good reputation on FTE.Turbo Dog has a good reputation on FTE.Turbo Dog has a good reputation on FTE.
What are the performance differences in the two differnt intake manifold designs? Why chose one over the other?
Old 06-16-2014, 05:51 PM
xlt4wd90's Avatar
xlt4wd90 xlt4wd90 is offline
xlt4wd90 is gaining momentum as a positive member of FTE.
The split plenums are usually to optimize flow for lower rpm ranges, while the open plenums are usually for higher rpm ranges. There are many manifolds of both designs whose operating range overlap each other, depending on the design.
Old 06-16-2014, 07:31 PM
Turbo Dog's Avatar
Thanks, that's what I was thinking but I wasn't sure. I think the split plenum is used to get a smaller plenum volume to allow more flow velocity at lower rates as compared to a big open plenum being able to flow more voume at higher rates.
My 460 came with a Weiand split plenum high rise manifold. That should make it a bit better for the street than an open plenum design.
I don't know what cam is in it and it has stock heads. I'm guessing the heads aren't ported because it was built using stock exhaust manifolds. It does have a nice dual exhaust.
floor Mats blackford4x4 Excursion - King of SUVs 11 04-04-2016 03:08 PM
78 Ford F250 2WD rim designation jschluter 1973 - 1979 F-100 & Larger F-Series Trucks 0 02-19-2016 07:18 PM
Fuel Pump? creedua 1980 - 1986 Bullnose F100, F150 & Larger F-Series Trucks 5 09-20-2015 07:06 AM
V8 Flathead - sold FortyNiner Ford Truck Parts for Sale 0 04-02-2015 10:06 PM
WTB headers (Hedman or other 6-2 design) for a 300 Six Triffecpa WTB - Parts & other 0 01-12-2015 04:10 PM
Search this Thread:
Advanced Search
Posting Rules
You may not post new threads
You may not post replies
You may not post attachments
You may not edit your posts
BB code is On
Smilies are On
[IMG] code is On
HTML code is Off
Trackbacks are Off
Pingbacks are Off
Refbacks are Off
Forum Jump
