High altitude jetting - Ford Truck Enthusiasts Forums
Old 06-16-2014, 09:16 AM
Turbo Dog's Avatar
Turbo Dog Turbo Dog is offline
Turbo Dog has a good reputation on FTE.Turbo Dog has a good reputation on FTE.Turbo Dog has a good reputation on FTE.
I live at 7200 ft and the truck I recently bought with a 460 was built in SoCal. It was obviously running too rich. I tore the Edelbrock 1407 750 cfm carb down this weekend and found the primary jets were .107 and the secondary were .110. I replaced the primary with a .104 and used .043x.071 rods.
I haven't had a chnace to start the engine yet and I am wondering if anyone else has set up one for high altitude use or has a manual with suggested sizes.
I put in a full rebuild kit and found the float settings to be off. the float level was too low and the float drop was also too low. Anybody ever make float level adjustments to help their performance?
Old 06-16-2014, 09:56 AM
Turbo Dog's Avatar
I just thought about searching for a manual...and here it is:
http://www.edelbrock.com/automotive/...ers-manual.pdf
Old 06-16-2014, 12:34 PM
Turbo Dog's Avatar
Looking through the manual and considering that the truck will most likely see a range form 5000 to 7000 ft I should be using a .107" jet with a .065x.047 rod. I'll swap that in before I install the carb in a few days and report back on how it worked.
7265 LawnBoy Running Rich - ? Buehler? Tedster9 General NON-Automotive Conversation 14 01-12-2017 07:22 PM
Holley Power Valve, Selecting, Testing and Quality Argess FE & FT Big Block V8 (332, 352, 360, 390, 406, 410, 427, 428) 49 09-13-2009 05:51 PM
Holley 4160 Jet & Adjustment Questions sdkoz Fuel Injection, Carburetion & Fuel System 5 12-16-2004 03:30 PM
Problem Setting Float Level on Holley 390 drive_old_ride_new Fuel Injection, Carburetion & Fuel System 8 12-03-2004 02:43 PM
holley 4180c used on 86 315w, adjustment screw question??? mgm415 Small Block V8 (221, 260, 289, 5.0/302, 5.8/351W) 5 12-19-2001 05:01 AM
Search this Thread:
Advanced Search
Posting Rules
You may not post new threads
You may not post replies
You may not post attachments
You may not edit your posts
BB code is On
Smilies are On
[IMG] code is On
HTML code is Off
Trackbacks are On
Pingbacks are On
Refbacks are On
Forum Jump
