6.4L Lower left coolant leak
I have a 2008 6.4L that I have noticed over the past couple weeks that it will leak a small puddle/drips of antifreeze on the garage floor. The coolant runs down the frame rail just below the lower corner of the radiator. Can't tell where it is coming from for certain. The radiator is still original (to my knowledge). Truck only has 56K miles on it, but of course the warranty is gone. Seems like this only leaks when I have pulled one of my trailers and or pushed (built more than 35 psi of boost). Doesn't always leak, or at least I haven't noticed it leaking all the time.
I have searched this site and found so many issues with coolant leaks and each has their own story on what they have done to the truck. I didn't find one that talks about a coolant leak on the driver's side running down the frame rail. Maybe I missed it or didn't refine my searches enough. If that is the case maybe someone can help point me in the right direction. Thanks if advance for everyone's help.
Looks like it's the plastic tank seam leaking on my radiator. Here's a pic of the area with a drip of antifreeze on the corner. Just before I shut it off it would drip steady running down the bottom 1 inch or so of the front seam.
Lower driver's side radiator thru front bumper by tow hook.
