1991 f250 460 chip help - Ford Truck Enthusiasts Forums
Old 06-16-2014, 12:49 AM
Usaallday's Avatar
Usaallday Usaallday is offline
Usaallday is starting off with a positive reputation.
I have a 1991 f250 with the 460 v8. I was looking into getting a performance chip. All I could find was a chip by Jet Performance. I was wondering if a chip like Bully Dog or Diablo could be used on my truck. Thanks.
Old 06-17-2014, 01:41 PM
Conanski's Avatar
Conanski Conanski is online now
Conanski has much to be proud ofConanski has much to be proud ofConanski has much to be proud ofConanski has much to be proud ofConanski has much to be proud ofConanski has much to be proud ofConanski has much to be proud ofConanski has much to be proud ofConanski has much to be proud ofConanski has much to be proud of
Chips are a complete waste of time on this vintage truck, you will get the same results buy just advancing the base timing at the distributor. Then the route to more power involves getting more air through the motor, so remove the intake airhorns if you haven't already done so and replace the whole exhaust system and manifolds with headers and whatever you like behind them. After that you got to go inside the motor.
Old 06-17-2014, 04:06 PM
Usaallday's Avatar
Quote:
So what should I advance the timing to? And would shorty headers add enough horsepower for me to be able to feel it cause long tubes aren't legal in California.
Old 06-17-2014, 08:05 PM
Conanski's Avatar
Most engines will tolerate 12-14deg initial advance, stock setting is 10 so throw a couple more degrees in and test drive it to see if it pings, if not try some more until you find where it does. Note you must remove the spout plug to disable computer advance before setting the base timing, and the spout plug is located in the TFI harness.
Shorty headers will produce noticable gains if everything behind them is also upgraded, you likely still need a cat but all the aftermarket cats flow more than the stock unit.
Old 06-21-2014, 08:04 PM
85e150six4mtod 85e150six4mtod is offline
85e150six4mtod has a superb reputation85e150six4mtod has a superb reputation85e150six4mtod has a superb reputation85e150six4mtod has a superb reputation85e150six4mtod has a superb reputation85e150six4mtod has a superb reputation85e150six4mtod has a superb reputation85e150six4mtod has a superb reputation85e150six4mtod has a superb reputation85e150six4mtod has a superb reputation85e150six4mtod has a superb reputation
Doug Thorley makes CARB approved headers, not sure about your application.
Your timing will have to go back to stock for your smog tests.
Edge CS programmer blew up my PCM? Vin Diseal 1999 to 2016 Super Duty 3 08-05-2015 08:33 PM
Edge Juice performance chip ramirez7589 6.0L Power Stroke Diesel 6 03-19-2015 01:23 PM
Dropped to idle and no throttle SBFD8 1999 - 2003 7.3L Power Stroke Diesel 16 10-09-2014 06:49 PM
needing help with performance chip's 95F-150EddieBauer Computer Chips & Tuners 3 08-13-2013 02:13 PM
1991 F250 4x4 Gary Roberson 1987 - 1996 F150 & Larger F-Series Trucks 8 02-23-2011 11:08 AM
Search this Thread:
Advanced Search
Posting Rules
You may not post new threads
You may not post replies
You may not post attachments
You may not edit your posts
BB code is On
Smilies are On
[IMG] code is On
HTML code is Off
Trackbacks are Off
Pingbacks are Off
Refbacks are Off
Forum Jump
