Parts source shifter and brake boots 70s f 600 - Ford Truck Enthusiasts Forums
Large Truck My truck is bigger than yours. The forum for 2+ ton trucks (all years), COE's, Louisville's, Big-Job's etc.
Old 06-16-2014, 12:16 AM
Notmeofficer's Avatar
Notmeofficer Notmeofficer is offline
Notmeofficer is gaining momentum as a positive member of FTE.
Nothing in google
Does anyone have a source for shifter boots and e-brake boots for 73-79 ford f600's?
I can custom make them but I would much rather prefer to buy them if possible
Thanks
notme
Old 06-20-2014, 05:23 PM
78_f800crewcab4x4's Avatar
78_f800crewcab4x4 78_f800crewcab4x4 is online now
78_f800crewcab4x4 is a name known to all78_f800crewcab4x4 is a name known to all78_f800crewcab4x4 is a name known to all78_f800crewcab4x4 is a name known to all78_f800crewcab4x4 is a name known to all78_f800crewcab4x4 is a name known to all
Uhaul has been selling off old f600 stuff on eBay.
Old 06-20-2014, 05:25 PM
Thanks....
Will look for those
A member has repos on here but they aren't exact matches
Old 06-20-2014, 07:54 PM
So.. there are few old stock sources and most of the after market stuff is way off. Uhual didnt have anything...their f600 stuff is getting sparce
I did find a dana 20 shift boot that is close in size so I ordered one up for the ebrake # 5353263.. Ill let everyone know how they fit... about 16.00
Shifter boots are easy.. if you cant find a new old stock.. great.. I have one but I want three so all my f600s have nice new boots... there are plenty of choices out there that will easily cover the hole in a sano manner
I like this one
Dorman 924-5405 Shift Boot
Its huge.. but will easily do the job.. about 25.00
way better than 60 plus dollars for repos.. that arent exact fit...
Ill report on the results so everyone can have some value options
thanks
notme
Old 06-25-2014, 10:59 PM
NumberDummy's Avatar
NumberDummy NumberDummy is online now
Ford Parts Specialist
NumberDummy has a superb reputationNumberDummy has a superb reputationNumberDummy has a superb reputationNumberDummy has a superb reputationNumberDummy has a superb reputationNumberDummy has a superb reputationNumberDummy has a superb reputationNumberDummy has a superb reputationNumberDummy has a superb reputationNumberDummy has a superb reputationNumberDummy has a superb reputation
Quote:
Originally Posted by Notmeofficer View Post
Does anyone have a source for shifter boots for 73-79 ford F600's?
Gee whiz, haven't you obtained the parts catalog yet?
7277 - Trans shift lever boot: Notice that 1979 (D7TZ-7277-A) is different than 1973/78 (D5TZ-7277-A). Both available NOS
Old 06-26-2014, 12:40 AM
THanKs bill
I do have thAt dang parts manual but it takes a ford parts guy to read it...
Ok.. brake lever boot
This is what Im using.. a dana 20 boot.. note how close it is.. so close it could be a clone.. except better made and more heavy duty rubber.. about 16.00 Crown automotive part number J5353263
The original is on the right (obviously) the new dana 20 boot on the left.. the trim ring is on it and fit perfectly... the picture is a little misleading.. they are actually very close in size with the new boot being slightly longer.. but that extra length is hidden under the trim ring... it will make an excellent seal
Old 06-26-2014, 01:32 PM
I do have that dang parts manual but it takes a ford parts guy to read it.
Ok.. brake lever boot.
2A713 - Boot-Parking Brake Lever.
Notice there are two types for model 81 2WD: 1973 before serial number S00,001 (C7TZ-2A713-B).
1973 from serial number S00,001 and 1974/79 (C7TZ-2A713-D). Both available NOS
Old 06-27-2014, 12:19 AM
Bill.. my factory boots dont match the descriptions at all (one on the 73 and one on the 79 2wd's.. exactly the same (even my 79 4 x 4 is the same)
MEASURING THE FACTORY BRAKE BOOT is as follows
8 1/2 inches long by 4 1/2 inches wide,, tip to tip and width to width
The screw holes are 3 3/8 inches wide center to center
and 7 1/2 inches long center to center...
Yes they are available old stock (limited),, and one of the parts numbers is very reasonable,, the others are from expensive nos places.. 45.00 and up..
Transfer Case Shifter Boot GreenMtnMan 1987 - 1996 F150 & Larger F-Series Trucks 14 09-29-2016 12:02 PM
Found a perfect shift / e-brake boot... Connecticut Calvin 1948 - 1956 F1, F100 & Larger F-Series Trucks 14 12-01-2015 11:05 PM
Ned help finding rubber boots candoo 1961 - 1966 F-100 & Larger F-Series Trucks 2 03-25-2015 10:56 AM
Cutch fork dust boot source 70's f600? Notmeofficer Large Truck 10 08-12-2014 05:00 PM
Shifter boot and hand brake boot bobfl 1961 - 1966 F-100 & Larger F-Series Trucks 1 04-23-2002 06:47 PM
Search this Thread:
Advanced Search
Posting Rules
You may not post new threads
You may not post replies
You may not post attachments
You may not edit your posts
BB code is On
Smilies are On
[IMG] code is On
HTML code is Off
Trackbacks are Off
Pingbacks are Off
Refbacks are Off
Forum Jump
