ground wire location? - Ford Truck Enthusiasts Forums
Ranger & B-Series All Ford Ranger and Mazda B-Series models
Old 07-08-2003, 06:09 PM
RCsanjose RCsanjose is offline
RCsanjose is starting off with a positive reputation.
i have a 2000 ranger with a 4.0 5 sp auto... when i tried starting the truck all i get is a single "click" after taking out the starter and testing it and checking all the wires connected to it i found that the main ground wire connected to the battery had the other end hiding up neat the front of the block near the pulley and it was not connected to anything ? ? ? ?
can someone tell me where this wire should be mounted... on the frame? to the engine block? ? and what size bolt will i need to buy? ?
thanks for any help... RC
Old 07-12-2003, 12:35 AM
UK02Ranger UK02Ranger is offline
UK02Ranger is starting off with a positive reputation.
Ground wires can be attached to the frame, make sure you have a good rust/paint/grease free surface to attach it to. Any bolt or whatever will do.
Old 07-14-2003, 01:48 PM
i actually went and looked at my uncles ranger and it is supposed to be connected at the starter... i guess someone changed it before i bought it 10 months ago and just tucked it under the block to get it out of the way and didnt put it back.... amazing it was ground enough for the last 10 months and didnt get knocked loose sooner... all is fine now...thanks...RC
Tachometer not working properly yankeerebel 1973 - 1979 F-100 & Larger F-Series Trucks 2 11-30-2016 06:42 PM
GROUND STRAP HOT FRANKLIN0716 Excursion - King of SUVs 10 01-15-2016 12:43 PM
Need some help wiring! 62integral 1961 - 1963 F100 Unibody 2 03-08-2014 02:07 AM
alternator problem or ground problem jaydgraff 1961 - 1966 F-100 & Larger F-Series Trucks 4 04-26-2013 01:57 PM
460 ground cable replacement bikeymikey 1987 - 1996 F150 & Larger F-Series Trucks 13 03-24-2013 10:00 PM
Tags
2000, 2008, 91, buy, chassis, f150, ford, frame, ground, location, locations, ranger, truck, wire, wires
Search this Thread:
Advanced Search
Posting Rules
You may not post new threads
You may not post replies
You may not post attachments
You may not edit your posts
BB code is On
Smilies are On
[IMG] code is On
HTML code is Off
Trackbacks are On
Pingbacks are On
Refbacks are On
Forum Jump
