Fixing blown helicoil 2v engine - Ford Truck Enthusiasts Forums
1999 to 2016 Super Duty 1999 to 2016 Ford F250, F350, F450 and F550 Super Duty with diesel V8 and gas V8 and V10 engines
Old 06-15-2014, 11:18 PM
powerstroker100 powerstroker100 is offline
powerstroker100 has a good reputation on FTE.powerstroker100 has a good reputation on FTE.powerstroker100 has a good reputation on FTE.
I tried searching on this but didn't find any solid info.
2002 f250 5.4l
So spark plug blows out, gets helicoiled by a local shop then spits out again, now I have to fix it.
I want to timesert the heads, however I don't know if it will work where the helicoil used to be. I am looking at buying kit 5553 but don't think it will work, can anyone give me help that has been in this position?
Thanks
Old 06-16-2014, 12:46 AM
dkf's Avatar
dkf dkf is offline
dkf is a splendid one to beholddkf is a splendid one to beholddkf is a splendid one to beholddkf is a splendid one to beholddkf is a splendid one to beholddkf is a splendid one to beholddkf is a splendid one to beholddkf is a splendid one to behold
Timesert offers what they call a "Big Sert" for previous failed repairs. They also offer a triple oversize kit if they are really screwed up. They list the OD thread size of the inserts on their site.
http://www.timesert.com/html/bigsert_sparkplug.html
Old 06-16-2014, 06:30 AM
projectSHO89 projectSHO89 is online now
projectSHO89 has a brilliant futureprojectSHO89 has a brilliant futureprojectSHO89 has a brilliant futureprojectSHO89 has a brilliant futureprojectSHO89 has a brilliant futureprojectSHO89 has a brilliant futureprojectSHO89 has a brilliant futureprojectSHO89 has a brilliant futureprojectSHO89 has a brilliant futureprojectSHO89 has a brilliant futureprojectSHO89 has a brilliant future
The "Bigsert" is their standard insert and is what the 5553 kit uses. If you need the triple oversize insert, you will need an additional tool kit.
Timesert says that the Bigsert will repair most blown helicoils. It depends on how big it was drilled out for the helicoils.
Old 06-16-2014, 12:12 PM
Thanks for your responses guys.
Ok so I just found out that when the first plug blew out, the owner of the truck brought it to the shop to have the blown spark plug well inserted but also had the other 7 plug wells inserted, is there a way to remove the helicoils in the other wells or just wait for them to pop.
also I did a little research, I think the shop used the helicoil kit where you tap the spark plug well, it appears the helicoil tap is 17mm and the timesert (5553 kit) inserts or "big-serts" are 18mm OD, 1mm is not much room but I'm wondering if I could use the 5553 kit to repair this blown helicoil plug and it will be solid.
Has anyone used the triple oversize insert and tools? how did it work?
Old 06-21-2014, 10:12 PM
MitchPeters MitchPeters is offline
MitchPeters is gaining momentum as a positive member of FTE.
I used the cheap autozone kit on my V10 and the both came out. I bought a Blue Point kit from Snap On and the insert was big enough to repair both of them. The kit is $400 though.
Old 06-23-2014, 09:38 PM
Yeah, I was going to big-sert the two but then he said he didn't want it and took his truck back
Timesert after failed Helicoil on blown plug? ftowelding Modular V10 (6.8l) 3 08-13-2015 12:33 AM
Spark plug helicoil back-out TNoble1 1999 to 2016 Super Duty 3 02-12-2015 09:23 PM
Thermostat Housing bolts, I just broke both of them... 2500ak 1967 - 1972 F-100 & Larger F-Series Trucks 21 12-06-2014 11:58 AM
Big cert experience? 78bigunns Excursion - King of SUVs 4 11-24-2014 05:09 PM
Helicoil Removal Cuw45 Modular V10 (6.8l) 8 06-03-2014 09:45 AM
Search this Thread:
Advanced Search
Posting Rules
You may not post new threads
You may not post replies
You may not post attachments
You may not edit your posts
BB code is On
Smilies are On
[IMG] code is On
HTML code is Off
Trackbacks are Off
Pingbacks are Off
Refbacks are Off
Forum Jump
