Uneven Bed
Old 06-01-2015, 10:25 AM
sweeted's Avatar
sweeted
sweeted is offline
Uneven Bed
I could use some advice on getting the box on my 1956 F-100 level.The right side is 5/8- 3/4" lower on the pass side. Can it be shimmed or is it an issue with the running boards also.Any help from those that know would be great.
Old 06-01-2015, 10:31 AM
sweeted's Avatar
sweeted
sweeted is offline
Old 06-01-2015, 10:34 AM
Normalbloke's Avatar
Normalbloke
Normalbloke is offline
Is it definately the bed or the cab?
Old 06-01-2015, 10:38 AM
sweeted's Avatar
sweeted
sweeted is offline
I measured from the shop floor to the top rear of the box, cab is setting fine.
Old 06-01-2015, 11:09 AM
52 Merc's Avatar
52 Merc
52 Merc is offline
Received 2,448 Likes on 1,396 Posts
You can shim the bed, but it might be better to investigate a little further and determine why the bed is uneven, rather than throwing a band-aid on it without checking to see if something is broken. My 2c.
Old 06-01-2015, 11:53 AM
AXracer's Avatar
AXracer
AXracer is offline
This is not a normal or common problem, there is something else wrong. Are you measuring the bed to the floor or to some other part of the truck? First block/shim the frame level front to back and side to side (check that the rear of the frame is level side to side when the front is level) then measure everything from the floor and/or check level. I expect you will find you have a twist in the frame, bed, worn/collapsed rear cab mounts, or sagged suspension.
Old 06-01-2015, 01:02 PM
sweeted's Avatar
sweeted
sweeted is offline
Well I measured and put a level to everything. The font of the box is dead level. Rear shock perches measure out perfect. I think the issue is with the right rear leaf springs,blocking off the axle is the same height and there is no shackle adjustment so I'm thinking that I may have some leaf sag.The floor to frame is good but the floor to rear leaf shackles are off.
Old 06-01-2015, 01:18 PM
AXracer's Avatar
AXracer
AXracer is offline
If the lean is in the suspension, it's not unusual for the driver's side suspension to sag more than the passenger side due to there being more weight being consistently carried on that side. Also you may have a cracked spring leaf and/or worn spring eye bushings and shackle pins on that side.
Old 06-01-2015, 01:47 PM
sweeted's Avatar
sweeted
sweeted is offline
The hunt continues. Think I'll get the jack under the rig and see if I can make a discovery?This truck was my Grandads and given to me from my Uncle (who did the resto).He is 78 now and he may have had a heavy right foot.Truck is using the factory 393 rear end and he said that he wanted to replace it, so if I do not find the issue I may add to that leaf to get that level until it gets a 9" or 8.8.
Old 06-01-2015, 06:40 PM
Doc's Avatar
Doc
Doc is offline
Ten bucks says one of the bed mounting bolts is torqued more than the others. Loosen them all up just slightly and re-measure. Been there. Done that.
Old 06-09-2015, 05:34 PM
rhopper's Avatar
rhopper
rhopper is offline
My F1 bed is crooked too. The cross members were all bent, cracked or broken. I welded and straightened as best as I could, but it's still not level. In my case, when I remove the bed for paint, I'm going to replace all the cross members with square tube.
BioBurner
1999 to 2016 Super Duty
03-03-2018 06:05 AM
tbirdscott
16
09-15-2012 11:40 AM
taylor90
39
02-28-2011 12:38 PM
ArtsBest
2010 - 2014 Ford SVT F150 Raptor
01-11-2010 01:55 PM
Fishin Technician
12-05-2002 07:18 PM
Quick Reply: Uneven Bed
