I Could Stand A Little More Power
Old 11-20-2014, 12:00 AM
wantahertzdonut's Avatar
wantahertzdonut
wantahertzdonut is offline
I was under the impression the PCM would need to be reflashed in order to use any of the aftermarket tunes. Is that not true?
I do plan on changing the filter. The truck is sitting right now because I'm in between layoffs and don't drive the truck to work. I've read some of the threads on the 6637 filter and will get around to that soon along with some steering improvement and shocks.
Do you have links to these chip manufacturers? How does one go about installing them anyway? Everyone says "chip", is there something similar to an SD card you have on your PC but made for an engine tune?
A word of note, while I have an OH registration, I'm in CA and may be here a while and may have to resort to CA registration. Are these tunes CA smog compliant?
Old 11-20-2014, 08:42 AM
oldbird1965's Avatar
oldbird1965
oldbird1965 is offline
The PCM doesn't have to be reflashed. The chip sits on back of the PCM but the PCM has to be pulled to clean the terminals. Only clean off the plastic coating, not any more! I couldn't tell you about smog conpliant, I wouldn't tell them about it, LOL
Old 11-21-2014, 12:24 PM
cowmilker08's Avatar
cowmilker08
cowmilker08 is offline
Glenn, I don't think you have to remove the pcm to clean the pins.
Old 11-21-2014, 01:11 PM
fordman67's Avatar
fordman67
fordman67 is offline
Good luck with that
Old 11-22-2014, 07:49 AM
helifixer's Avatar
helifixer
helifixer is offline
Received 3,626 Likes on 1,118 Posts
I am with Glen (oldbird1965) on everything! not that far on modding. I am running stage 1 rosewood injectors and the t500 hpop. in stock programing with that I can not hit 1250 degrees after putting the after cooler on and fixing the exhaust leaks.
before modding I towed with the edge in 60 hp tune and ran 1250 for hours on end.
as for power, coming home from hunting with my 23' 5th wheel camp trailer (packed with stuff) and tanks full and the bed of my truck full of all the real heavy stuff I never shut my cruise control off on the 6% grade and I stayed at 72mph.
most of the time towing I get 10 to 14 mpg, when I haul hay I drop to about 8 mpg but I am over 26,000 lbs with that load.
Old 05-26-2015, 11:34 AM
wantahertzdonut
Who makes a decent 4" tail pipe? I've discovered mine is collapsed from where the axle made contact. I assume the current tailpipe was intended for another vehicle.
I tried calling a couple local shops and they won't bend anything over 3".
Old 05-26-2015, 11:49 AM
darknight's Avatar
darknight
darknight is offline
Originally Posted by wantahertzdonut
Where can I get a 4" tail pipe? I've discovered mine is collapsed from where the axle must have made contact. I assume the piece in there is incorrect.
WAIT!
If you want to start down this road, get your checkbook out now. All these experienced guys told me that and I thought
"Meh, my trans will be fine.. My stock turbo will be good... I'll get bigger than needed injectors and de tune them..."
2 years, 10 grand later I'm still not close to being done.
-Do the intake, exh, and a custom tuned chip. If that doesn't do it, get ready to spend. It can be awesome, get great mileage, be more powerful than you'll need, but it will cost you.
Old 05-26-2015, 02:11 PM
wantahertzdonut
Originally Posted by darknight
WAIT!
My current tailpipe is already 4", but it's damaged and squished about halfway shut. It needs replacement, this is not just an upgrade. I'm not going for big power, but the engine does need to breathe.
Old 05-29-2015, 05:52 PM
IDMooseMan's Avatar
IDMooseMan
IDMooseMan is offline
MBRP has a good system. I've had some terrible customer service from DiamondEye, but their system has worked quite well on my truck. If you know the manufacturer of your current system, why not call them for replacement parts?
It sounds like a rubber bumpstop or something is missing. I'd be concerned with what caused the current pipe to be smashed in the first place. If you don't address that situation, it will most likely happen again.
Old 05-29-2015, 06:43 PM
wantahertzdonut
I'll check those brands out, thanks for the pointers.
I don't know the brand of the exhaust on there now, it was on the truck when I bought it, but I do know it's not a piece meant for an F350. It isn't the right shape and it didn't have a big enough arch to clear the axle. Someone just used something that looked like it would go and they were wrong!
Old 05-29-2015, 07:14 PM
IDMooseMan's Avatar
IDMooseMan
In that case, it might be a good idea to order an entire system, from the turbo back, to ensure the system works properly and this doesn't happen again. I have the 4" turbo back aluminized system from DiamondEye. It works fine, but like I said, I'm not impressed with their customer service. I wanted, and ordered, their stainless steel system with the lifetime warranty, The shop received and installed their aluminized system with the one- or three- year warranty. I don't recall what warranty length it was, but either way, it's expired now.
f150longbed
02-26-2017 11:11 PM
lawdawg79
08-02-2015 09:00 AM
mismith
07-19-2012 11:13 PM
6.9lXLTf250
33
12-28-2011 05:57 AM
sharethewealth
16
03-08-2010 02:42 PM
Quick Reply: I Could Stand A Little More Power
