Transmission going into neutral while in D.
Old 06-15-2014, 10:41 AM
Buck Woodall's Avatar
Buck Woodall
Buck Woodall is offline
I have a 2004 F-150 (automatic trans. w/118,000k)and my transmission has been going into neutral while Idrive in D at about 30-45 miles per hour. I can turn overdrive off and drive in all three speeds without a problem. All other gears are working as well. I checked the fluid and it is full and clean. I also checked the overdrive fuse and it looks fine. Is there any chance its something simple or am I going to have to remove the transmission?
Old 06-15-2014, 07:42 PM
Phone_girl_NE's Avatar
Phone_girl_NE
Phone_girl_NE is offline
06 E359 5.4 4R75 207,000 miles. Trany freewheeled twice and within 200 miles dead. $2,600 for a 5 year 75K mile rebuilt. No other slipping that I noticed. Fluid was due but smelled fine.
I hope it all works out and is a simple fix.
Old 06-17-2014, 07:44 PM
70f100longbed's Avatar
70f100longbed
70f100longbed is offline
Most likely the snap ring for the overdrive servo broke and the piece is stuck in the valvebody. There are videos on youtube that detail how to fix it. It's not hard at all just be careful when removing and working on the valvebody. There are several check ***** inside that have to go back where they came from.
alwayschooseford
1999 to 2016 Super Duty
09-07-2010 03:44 PM
scott_pelletier
06-14-2009 01:54 PM
etucker
06-17-2003 09:37 AM
mackcat
1997 - 2003 F150
03-11-2003 03:55 PM
Quick Reply: Transmission going into neutral while in D.
