Transmission going into neutral while in D. - Ford Truck Enthusiasts Forums
Old 06-15-2014, 10:41 AM
Buck Woodall Buck Woodall is offline
Buck Woodall is starting off with a positive reputation.
I have a 2004 F-150 (automatic trans. w/118,000k)and my transmission has been going into neutral while Idrive in D at about 30-45 miles per hour. I can turn overdrive off and drive in all three speeds without a problem. All other gears are working as well. I checked the fluid and it is full and clean. I also checked the overdrive fuse and it looks fine. Is there any chance its something simple or am I going to have to remove the transmission?
Old 06-15-2014, 07:42 PM
Phone_girl_NE Phone_girl_NE is offline
Phone_girl_NE is starting off with a positive reputation.
06 E359 5.4 4R75 207,000 miles. Trany freewheeled twice and within 200 miles dead. $2,600 for a 5 year 75K mile rebuilt. No other slipping that I noticed. Fluid was due but smelled fine.
I hope it all works out and is a simple fix.
Old 06-17-2014, 07:44 PM
70f100longbed's Avatar
70f100longbed 70f100longbed is offline
70f100longbed has a very good reputation on FTE.70f100longbed has a very good reputation on FTE.70f100longbed has a very good reputation on FTE.70f100longbed has a very good reputation on FTE.
Most likely the snap ring for the overdrive servo broke and the piece is stuck in the valvebody. There are videos on youtube that detail how to fix it. It's not hard at all just be careful when removing and working on the valvebody. There are several check ***** inside that have to go back where they came from.
95 f150 transmission HELP!! Laneely84 1987 - 1996 F150 & Larger F-Series Trucks 6 10-27-2015 05:12 PM
1993 E40d need help markusjoshua 1987 - 1996 F150 & Larger F-Series Trucks 13 03-14-2015 07:14 PM
Trans Slip pfeifer5 1997 - 2003 F150 2 12-28-2014 04:09 PM
2005 f150 transmission problem challahan 2004 - 2008 F150 9 06-02-2014 06:33 PM
Shifter wont go in to transmission 81 f100 cook134 1980 - 1986 Bullnose F100, F150 & Larger F-Series Trucks 0 03-22-2014 11:53 PM
Search this Thread:
Advanced Search
Posting Rules
You may not post new threads
You may not post replies
You may not post attachments
You may not edit your posts
BB code is On
Smilies are On
[IMG] code is On
HTML code is Off
Trackbacks are Off
Pingbacks are Off
Refbacks are Off
Forum Jump
