7.3 Starts then Stalls
Old 06-15-2014, 09:50 AM
chrisbrady498's Avatar
chrisbrady498
chrisbrady498 is offline
Hey guys take a look at the video of my truck below. Any idea on what it could be? It won't stay running. This video is the longest I've gotten it to run. I ran it last weekend fine. Let it sit this week when it was pretty rainy and now I've got this problem. Any ideas?
2000 7.3 STARTS THEN DIES: http://youtu.be/3FJ7skh_cx0
Old 06-15-2014, 10:51 AM
guitarpicr's Avatar
guitarpicr
guitarpicr is offline
Can you check fuel pressure. Also is hpop full of oil. Should be about 1" from top ?Oil is clean & full on dipstick ?
Old 06-15-2014, 11:04 AM
nlemerise's Avatar
nlemerise
nlemerise is offline
Do you have a spare CPS? I noticed that the tach doesn't move when cranking...easy to check and you should have a spare with you at all times anyway. Don't get one at a auto parts store, get a genuine Ford or IH.
Old 06-15-2014, 12:06 PM
Pikachu's Avatar
Pikachu
Pikachu is offline
Well, you've got an SES light. Do you have any way to read the codes?
Old 06-15-2014, 12:56 PM
chrisbrady498
Oil is good
chrisbrady498
Is that definitely the cps?
Old 06-15-2014, 12:57 PM
chrisbrady498
Yea I've read the codes there's 2 for glow plugs and an air temp sensor and turbo manifold pressurr
Old 06-15-2014, 12:59 PM
chrisbrady498
I ended up getting it running, it just started for me and I kept the rpms at about 2k for a minute and then it died. Started it up and same as video. Started it again and kept it at 2k then idle then giving the pedal a hit a few times. Seems to be okay now. Anyone have any idea what coulda caused it?
Old 06-15-2014, 01:15 PM
Pikachu's Avatar
Pikachu
Pikachu is offline
The way the tach was jumping around, I'd lean toward something CPS related. It may not be the sensor itself, but they're inexpensive and easy to change. It could be a wiring problem, bad ground, or even moisture in a connector, too.
Old 06-16-2014, 08:27 AM
nlemerise's Avatar
nlemerise
No, had it been definite I would have stated that. It just seemed to me an electric sensor problem and the tach was acting weird - cranking showing 0 RPM. It is an easy swap and you should always carry a spare anyway because if you don't have a spare, when it gives out you will be on the side of the interstate at 2 AM in the rain , with no spare CPS. Oh and carry the correct wrench to change it out too.
Newbie 7.3
1999 to 2016 Super Duty
12-18-2017 02:50 PM
levilevi32
09-03-2017 10:44 AM
donmi
07-26-2015 08:33 PM
new7.3owner
31
05-16-2014 06:43 PM
fordmerc
01-12-2010 08:35 PM
Quick Reply: 7.3 Starts then Stalls
