66 F100 Build
  #121
Old 09-07-2015, 05:31 PM
red66rider's Avatar
red66rider
red66rider is offline
Truck looks really good
  #122
Old 10-04-2015, 04:31 PM
66ordie's Avatar
66ordie
66ordie is offline
I got the inner fenders and a few other parts in and with all the wet weather I was able to lock myself down for awhile and make some progress on getting the front end reassembled, still. There is no rust left on this truck and it's taking time but hey that's all we have is time.
The inner fenders turned out great
Core support powder coated a d front upper and lower valances were blasted and primed.
19" mustang rims
She is starting to go back together and look like a truck again.
  #123
Old 10-04-2015, 04:36 PM
66ordie's Avatar
66ordie
66ordie is offline
With almost all the weight back on the front end I don't know if I like the height, so I may look at some options to lower it a few inches
  #124
Old 10-04-2015, 05:32 PM
Jacks 65's Avatar
Jacks 65
Jacks 65 is offline
What is the height from the floor to the bottom of the fender well above the front wheels? I'm almost done with my truck and I am now considering doing this swap...should have before I got as far as I did...the build looks great by the way!
  #125
Old 10-04-2015, 05:59 PM
66ordie's Avatar
66ordie
66ordie is offline
I hope this helps
  #126
Old 10-04-2015, 06:19 PM
Jacks 65's Avatar
Jacks 65
Jacks 65 is offline
Thanks!!! I'm considering doing a shockwave airbag system. I don't want to "lay frame" but lower for sure
  #127
Old 10-06-2015, 06:55 AM
66ordie's Avatar
66ordie
66ordie is offline
I was checking out the progress, slow of course but it's getting there, the front clip is together and back in place, I want it to last another 50 years so it's worth taking the time and doing it right.
After......
Before...
  #128
Old 10-06-2015, 08:17 AM
37 Ford guy's Avatar
37 Ford guy
37 Ford guy is offline
Nice work! It's good to see you went with black on the core support. That lets the beauty of these cool grilles stand on their own without the distraction of the body color showing through that area and cheapening the overall look of the truck. That's a personal opinion, of course.
  #129
Old 10-06-2015, 09:14 AM
svolpone's Avatar
svolpone
svolpone is offline
where did you get the core support? it looks new. i need one. mine is toast.
  #130
Old 10-06-2015, 04:49 PM
66ordie's Avatar
66ordie
66ordie is offline
I picked it up from Dennis Carpenters in NC, it's a 64 and I had it modified to match the 66, I took the old one and the new one to a fabricator and had him match it up.
  #131
Old 10-08-2015, 05:10 AM
66ordie's Avatar
66ordie
66ordie is offline
Thanks, I agree I want the grill to stand out, not sure yet what the final color will be.
  #132
Old 10-08-2015, 05:17 AM
66ordie's Avatar
66ordie
66ordie is offline
what makes you choose that system, I'm skeptical on an airbag system because I don't want to take up space with all the extras that come along with it, at the same time the front end needs to drop about another two inches. I need to get the bed and everything else installed and check the stance then but I do want to drop the front a small bit so I'm thinking of just modifying the front struts ..... What are your thoughts?
  #133
Old 01-11-2016, 05:19 AM
66ordie's Avatar
66ordie
66ordie is offline
I ordered the new transmission and it should arrive by the end of the month, so I decided to pull the motor early and get a few other things done as well. The oil pan drain plug landed right on the crossmember so I had to swap out the oil pans. Since the motor is out it gets cleaned up as well
The clutch appears to be in decent shape so it will get reinstalled, that saves some money and that makes me happy
  #134
Old 02-07-2016, 06:31 AM
66ordie's Avatar
66ordie
66ordie is offline
The new transmission arrived, T5 with an adapter plate that needed to be installed on the bell housing. The adapter is on and getting ready to install the motor.
  #135
Old 02-27-2016, 04:58 PM
66ordie's Avatar
66ordie
66ordie is offline
I had time to get back at it today, the new transmission arrived weeks ago and I fixed the adapter plate to the bell, and am putting the motor in first then the trans from below only because I'm on my own today
Quick Reply: 66 F100 Build
