86 302 efi conversion
on
Yes you could use a '94 roller cam but it's not likely the block is roller ready(assuming it's a truck motor) meaning it won't have the raised bosses in the valley where the spider bolts down or the taller lifter bores so you would need to use linkbar roller lifters. If the motor is from a mustang then it already has the HO roller cam in it. If you're good with the cost of those lifters and the matching pushrods then it'll certainly work but it's not necessary to get a running motor as the stock cam in a regular 302 motor will work with EFI.
Ouch -- not much hp and torque in that one ..........don't get me wrong, 5.0s can go 500,000 miles, but can you pass and look for something with a little more torque??.................those truck motors are weak to say the least.......
on
What vehicle did your EFI parts come from?
P.S. If you get an early carbed or EFI motor with a flat tappet cam in it(pre '92 trucks) and you want a bit more power out of it and don't mind changing the cam then the COMP 31-255-5 is a healthy upgrade, is EFI friendly, and won't require any other parts besides new flat tappet lifters but these are often sold as a package with the cam for under $200.
nickmobile67
08-25-2007 06:20 AM
s1120
05-09-2006 10:13 AM
Country705
03-12-2006 09:09 PM
