Heil hydraulic hoist on a 57 f600 - Ford Truck Enthusiasts Forums
Large Truck My truck is bigger than yours. The forum for 2+ ton trucks (all years), COE's, Louisville's, Big-Job's etc.
Old 06-15-2014, 12:18 AM
57f600farmboy 57f600farmboy is offline
57f600farmboy is starting off with a positive reputation.
Hi guys i have a 1957 f600 in really good shape everything original and im in the process of restoring it and it has a heil hydraulic hoist well the hydraulic pump was leaking fluid so i thought i would fill it up but i couldnt find a resivor i am not sure how to fill this system i am replacing the hydraulic lines those were original to the truck and also every thing has a number on it besides the cylinder, the pump does have a number and i have the brass plate with the hoist model and serial number attached to the hoist itself i need to find a rebuild kit if possible if anone can help thank you if i am posting this on a wrong part of the site i am sorry haha
Thanks
Old 06-15-2014, 03:33 AM
big job's Avatar
big job big job is offline
big job has a very good reputation on FTE.big job has a very good reputation on FTE.big job has a very good reputation on FTE.big job has a very good reputation on FTE.
Good questions. The pump most likely seals. I think I would send it out
cause there is a million pumps out there and the hydraulic guys know
what their doing. Filling the system, most likely or common, its in the
cylinder. does it lift up at all? If not, Im afraid you will have to lift the
body up with a loader or something and pour hyd fluid in the top theres
a plug, fill with the pump running. Be prepaired, pour slowly or you will
get soaked. Always prop the body with 4x4's while under there. After
awhile you will hear the pump whinning add more fluid. Remove props
and unchain loader and work it up and down adding fluid till it goes all
the way up. be prepaired to use about 5 gal. depending.
does this help?
Old 06-15-2014, 01:50 PM
fellro86's Avatar
fellro86 fellro86 is offline
Iowa Benevolent Dictator
fellro86 has much to be proud offellro86 has much to be proud offellro86 has much to be proud offellro86 has much to be proud offellro86 has much to be proud offellro86 has much to be proud offellro86 has much to be proud offellro86 has much to be proud offellro86 has much to be proud of
I personally have never filled a lift system of this nature through the cylinder. There should be some kind of reservior, and a cap that looks like a breather typically. I have seen a few that had a pipe plug.
I have seen the pump (and currently have this arrangement) inside the reservior, and also have seen the pump separate from the reservior.
Old 06-15-2014, 09:51 PM
fivestarmmd fivestarmmd is offline
fivestarmmd is starting off with a positive reputation.
My fontain hoist uses cyl for resivour. Top is tank, lower end cyl.
Old 06-16-2014, 02:40 PM
does this help?
Thanks for replying, and i currently have the truck apart i'm restoring it and i have everything off of the truck but will be putting it back on and yes the system worked fine just needed new hoses and the pump fixed but with my pump it does have a plug but it is on the bottom, the cylinder does come apart easily i will be at the shop later if pictures would help thats no problem i wander if i turn the pump upside down to fill it up would work? Because that woluld be the only way to fill it, but the point is i fill it through the pump correct? That was my wonder was to fill the cylinder or the pump, thank you for your advice thanks again for replying
Old 06-16-2014, 06:07 PM
dmanlyr dmanlyr is offline
dmanlyr has a great reputation on FTE.dmanlyr has a great reputation on FTE.dmanlyr has a great reputation on FTE.dmanlyr has a great reputation on FTE.dmanlyr has a great reputation on FTE.
You do not fill it thru the pump.
As mentioned, you either have a reservoir built in as part of the cylinder, which is very common on 2-5 yard size box hydraulics or a separate reservoir that has a breather cap on it.
Either way, nothing to fill on the pump itself.
David
Old 06-16-2014, 07:35 PM
Thanks you guys i got it it was the resivor in the cylinder thanks again its working great, my grandpa put a new gasket kit on the pump for me and put new hoses on it i got the hoist back on and lifting good, well withought the bed on it still but anyway thanks again guys very much appreciated!
Anthony Hoist Ossiemac 1948 - 1956 F1, F100 & Larger F-Series Trucks 5 06-20-2016 11:00 AM
1964 Ford F600 292 exhaust manifold replacement arvet19 Large Truck 6 04-10-2015 03:55 PM
Old truck hoist oil ireding Large Truck 2 08-24-2014 03:57 PM
Truck hoist oil? ireding 1957 - 1960 F100 & Larger F-Series Trucks 3 08-24-2014 01:42 AM
56 Ford F-600 Dump - Hydraulic Pump Bucsfan552 1948 - 1956 F1, F100 & Larger F-Series Trucks 5 03-19-2012 09:19 PM
Search this Thread:
Advanced Search
Posting Rules
You may not post new threads
You may not post replies
You may not post attachments
You may not edit your posts
BB code is On
Smilies are On
[IMG] code is On
HTML code is Off
Trackbacks are Off
Pingbacks are Off
Refbacks are Off
Forum Jump
