The "wrench"
If you are getting laggy acceleration, it means that the computer isn't seeing the boost, or maybe there isn't boost.
Because you said there is black smoke, that probably means the boost isn't there to burn up the fuel.
So either the turbo isn't running right, or there is a problem with air flowing. Air filter good? What are you seeing for turbo PSI while driving?
If the PSI looks good, chances are it's an issue with too much EGR running into the intake, eliminating usable fresh air.
Air filters good.
Should I just get the EGR deleted first?
Wouldnt hurt anything to do it anyway would it?
PSI runs between 100-2000 normal driving.
If the turbo boost is low, then that shows the turbochargers not doing a good job, and not enough air being available to burn the fuel.
If the turbo boost is normal, that means something else is causing the air to be unusable, most likely exhaust in the intake, reducing available fresh air to burn fuel.
I meant boost psi. I hope it's not running 100 - 2000 psi boost lol.
Well it all depends on what your doing or how fast your driving, if its idling its around 100 , if your going down the road its around 2000?
Am I not answering right lol?
How would exhaust get in the intake?
Top left corner, I think, is turbo psi boost guage.
Totally stock, the boost will usually hit around 10-15 or maybe 20 psi down the highway. Thats driving nicer not towing.
Exhaust gets into the intake through the EGR system, it is designed to replace oxygen you don't require, and reduce emissions. If everything works perfectly, that is what happens.
Now you said it is sluggish, so the question is; is that because the boost from the turbochargers is low? Or is the boost fine, but the air to recirculated exhaust ratio is out of whack?
If the boost is showing normal range of numbers, that means the turbo should be working, but maybe too much exhaust.
If the boost is lower than normal, the issue could be the turbo or sensor.
Betting money, that either way this is a sensor issue.
Just let us know what the top left guage does, driving on hiway, accelerating, etc.
Try to find someone to read the codes off it, too.
Even if theres no fault codes stored, check out the temperature sensors and see if they look to be right.
I recently had an issue on a car, I know, totally different, but the coolant temp sensor was reading wrong, and baffled mechanics and made it run like crap. Nothing replaces spending time watching the values in the computer while its running and seeing what might cause an issue.
I think your looking at RPM's.
Ok I was out a zero on the boost.
Its in 10's I was talking 100's.
It says "PSIx10 so the guage goes to 4.
So mine runs at around 2 most of the time empty.
One thing Ive noticed is when its coasting , like when you take your foot off the gas pedal then step on it theres a lag before it picks up again?
A very noticeable lag,
If you are already stepping on the gas and step harder it takes right off with no lag
You said you were getting smoke when trying to pass, was it possibly steam?
The intercooler apparently can build up moisture, and when you hammer the throttle, it can build boost, and suck the water out of the intercooler, and blow a bunch of steam and white smoke out. could this be happening to you?
Otherwise, with boost decent, maybe EGR valve is sticking, somethings blocked, or a sensor is giving a false reading somewhere causing the computer to run too much EGR?
Can you get codes read?
Its the lag that's most annoying.
#28
Fordguy95
6.4L Power Stroke Diesel
13
04-09-2012 05:54 AM
spikedog
09-14-2009 09:31 AM
