Best clutch kit? - Page 3 - Ford Truck Enthusiasts Forums
Best clutch kit?
  #31
Old 06-27-2014, 11:19 AM
Royson12's Avatar
Royson12 Royson12 is offline
Royson12 is starting off with a positive reputation.
Quote:
Originally Posted by Talyn View Post
The stock replacement LUK kit is good.
DIY, I've never had to bleed the slave from pulling it and letting it release.
if yours is getting air in it from that, it means its got a leak inside.
I did get the Single Mass flywheel kit.
No leaks, I think it might have just sucked air into the master cylinder, when the rod came out. I hope.
  #32
Old 06-27-2014, 01:05 PM
coreyallan01's Avatar
coreyallan01 coreyallan01 is offline
coreyallan01 is gaining momentum as a positive member of FTE.coreyallan01 is gaining momentum as a positive member of FTE.
Once you get that clutch dialed your gunna love the actuation... I did a LUK back in Dec, great clutch!
  #33
Old 06-27-2014, 02:31 PM
Talyn's Avatar
Talyn Talyn is offline
Talyn has much to be proud ofTalyn has much to be proud ofTalyn has much to be proud ofTalyn has much to be proud ofTalyn has much to be proud ofTalyn has much to be proud ofTalyn has much to be proud ofTalyn has much to be proud of
Just stab the clutch a lot
hydraullics are supposed to bleed themselves.
You'll feel it come in and out and work the air out.
stab it a few times. let it rest. blah blah.
I had it happen the first time i did my clutch, but it never did it the last few times i've had the trans out.
  #34
Old 07-15-2014, 08:20 AM
Royson12's Avatar
Clutch works great! So far! Quiet! Pedal is soft on the knees! Lots of difference from the factory job!
  #35
Old 07-15-2014, 08:51 AM
Nice.. Did you end up exercising it a bunch to get the air out?
  #36
Old 07-15-2014, 08:54 AM
DIYMechanic's Avatar
DIYMechanic DIYMechanic is offline
DIYMechanic is a splendid one to beholdDIYMechanic is a splendid one to beholdDIYMechanic is a splendid one to beholdDIYMechanic is a splendid one to beholdDIYMechanic is a splendid one to beholdDIYMechanic is a splendid one to beholdDIYMechanic is a splendid one to behold
Good deal. I told you you would be happy with that kit. I like mine a lot.
Not a bump in the road...what's up Texas? mjunk1 1967 - 1972 F-100 & Larger F-Series Trucks 22 01-19-2016 07:05 PM
OT - Moving to Houston 38 coupe 1948 - 1956 F1, F100 & Larger F-Series Trucks 11 04-11-2015 11:20 PM
Anyone in San Antonio area who can time my 7.3 jmuenchow Pre-Power Stroke Diesel (7.3L IDI & 6.9L) 1 03-04-2015 06:21 PM
Diesel shop in S TX & IP Timing questions jmuenchow Pre-Power Stroke Diesel (7.3L IDI & 6.9L) 5 02-18-2015 09:45 PM
Saying HEY from San Antonio... TexasFordGuy2014 Texas Chapter 2 12-04-2014 08:30 AM
Search this Thread:
Advanced Search
Posting Rules
You may not post new threads
You may not post replies
You may not post attachments
You may not edit your posts
BB code is On
Smilies are On
[IMG] code is On
HTML code is Off
Trackbacks are Off
Pingbacks are Off
Refbacks are Off
Forum Jump
