Mystery Trans fluid leak
Hi, I have a 1988 f250 with a 5.0 engine. Not sure of the trans. I am using a lot of trans fluid with only a very small apparent leak at the dip stick tube. I assumed it was the vacuume mod so I crawled under to check it and cannot find one. The auto part staore shows they have one but I just can't seem to find it. All the other fords I have had It was at the right rear of the trans. I am going through about 3 qts oil per 100 miles driving with no obvious leaks. Leaves a small puddle about the size of a saucer after sitting for several weeks. No leaks I can see when running. Truck is only used for occassional lumber or hardware trips. It seems to shift fine as long as the level is up.
If a C6, the modulator diaphragm vac leak can bring trans fluid up to the intake where it gets burned in combustion, then sent out the exhaust.....
c6 trans got hot puked fluid, wouldnt hold fluid, got towed, today add fluid and it seems ok?..WHY??
F350dog
12-12-2015 03:26 PM
10bands
08-13-2007 03:43 PM
Mark Kovalsky
03-01-2002 07:22 PM
