ABS dash light
Old 06-14-2014, 07:48 AM
tjcprop's Avatar
tjcprop
tjcprop is offline
ABS dash light
Was told by a mechanic that since my 150 has larger tires (35s), larger gears (4.88) and diff (9.75) that the module has trouble reading the code therefore the ABS dash light is always on. Has anyone experienced this? Was also told to garbage The Edge programmer that I have installed. This programmer is a generic unit made for many trucks and these programs screwed up my module. Is this true???
Old 06-14-2014, 08:57 AM
1saxman's Avatar
1saxman
1saxman is offline
You probably have a loose or corroded connector at the ABS harness at one or more wheels. In any event, the act of checking each one and re-connecting is good maintenance.
Old 06-14-2014, 12:05 PM
tjcprop's Avatar
tjcprop
tjcprop is offline
New ABS sensors installed with all wiring double checked. Was told my a Ford Tech that this issue is caused by stated above problem. A new module was required with a flashing. Wondering if anyone else had this issue??
rockbust
03-05-2017 01:06 PM
jhmalaska
1983 - 2012 Ranger & B-Series
03-08-2013 09:22 AM
Bob Gervais
04-14-2010 09:09 PM
95_4x4_jay
04-07-2005 12:28 PM
Quick Reply: ABS dash light
