Fuel Transfer from Rear tank to front tank? - Ford Truck Enthusiasts Forums
Old 06-14-2014, 01:02 AM
Red 5 Red 5 is offline
Red 5 is starting off with a positive reputation.
I have a 1997 Ford F-350 with the 7.5 liter...
When I run it on the rear fuel cell it will transfer the fuel to the front fuel cell while I am driving... If the front fuel cell is full when I run it on the rear cell it will actually over fill the front tank and the fuel will run onto the ground while the truck is running.
Help, anyone?
Red 5
Old 06-14-2014, 03:09 AM
rockdawg84's Avatar
rockdawg84 rockdawg84 is offline
rockdawg84 is starting off with a positive reputation.
you have a bad fuel pump which has a built in check valve that has gone bad. I had the same problem on my 96 F350 CCLB 4x4. Change both pumps and be good. BTW the tank that is filling is the tank with the bad check valve.
Old 06-14-2014, 05:22 PM
Fuel Transfer
Thanks Rockdawg,
I will do that...
Old 06-16-2014, 06:47 PM
paulm paulm is offline
paulm is starting off with a positive reputation.
Help, anyone?
Red 5
I had the same issue on my '89 F250 and the problem was the fuel tank selector valve was not right. Depending on which tank is selected that particular fuel pump applies pressure to the valve. Mine trouble started with when I changed tanks one day and the truck died. I thought the fuel pump must have been bad so I switched back to the rear tank. Then the rear tank started pumping fuel into the front tank to the point that when I removed the front tank fuel cap gas would spray out at me. Shortly thereafter, I tried switching back and on the tank switch and it got to where the truck would not run at all. A check of the fuel lines after the fuel tank selector valve showed no gas going through the valve. Popped the lines loose on the tank side of the valve and both pumps were pumping great. Spent the $140 on a new valve and all is good.
Old 06-17-2014, 12:28 AM
rockdawg84's Avatar
in 97 the truck does not have a selector valve, instead each tank has a fuel module unit (FMU) that contains the pump, sending unit and backflow valves and they are simply energized individually to pump fuel and open the return valve. the FMU is for the most part not serviceable though I am sure that there are those who could.
water in fuel delima john johns Pre-Power Stroke Diesel (7.3L IDI & 6.9L) 3 09-24-2016 08:24 AM
doing hutch / harpoon and have question. carl2591 1999 - 2003 7.3L Power Stroke Diesel 23 07-23-2016 01:39 PM
In cab fuel cell Boomco 1973 - 1979 F-100 & Larger F-Series Trucks 7 03-29-2015 01:33 PM
Preferred fuel cell location?????? 2zwudz 1961 - 1966 F-100 & Larger F-Series Trucks 11 03-04-2014 04:38 PM
Replacing gas tanks with fuel cell? 1loud89 1987 - 1996 F150 & Larger F-Series Trucks 9 06-30-2013 09:02 PM
Search this Thread:
Advanced Search
Posting Rules
You may not post new threads
You may not post replies
You may not post attachments
You may not edit your posts
BB code is On
Smilies are On
[IMG] code is On
HTML code is Off
Trackbacks are Off
Pingbacks are Off
Refbacks are Off
Forum Jump
