Weld on axle wedges, Anyone used em??? - Ford Truck Enthusiasts Forums
Old 06-13-2014, 01:05 PM
EWHOLTZCLAW's Avatar
EWHOLTZCLAW EWHOLTZCLAW is offline
EWHOLTZCLAW is starting off with a positive reputation.
Ive got a set of axles out of a 3/4 ton pick up. The rear is a dana 60 and the front is a high pinion 44. The rear will be easy but the front i was wondering if anyone had used these before. They are for an early bronco but i think they would be the same for the 79 half ton that i have. You weld them onto the 44 high pinion axle so that they work with the existing radius arms and coil springs rather than using the leaf springs and changing the mounts on the frame. anyway if anyone has used these or done a swap like this (which im sure have) whats easier and whats better as far as travel and ride? Here is the link to the wedges.
Ford Dana 30 Dana 44 Dana 60 Axle Wedges (4) Weld On
DANA 50 TTB Experts, help needed. badasssapper67 1980 - 1986 Bullnose F100, F150 & Larger F-Series Trucks 6 03-17-2016 12:50 PM
Dana 44 HD Open knuckle f250 axle for an f150 ZarK-eh 1973 - 1979 F-100 & Larger F-Series Trucks 24 08-02-2015 01:28 PM
Paired dana 60s? Feardeere7 1973 - 1979 F-100 & Larger F-Series Trucks 13 05-13-2014 11:38 AM
Dana 60HD rear and Dana 44 front fluid capacity kilich 1973 - 1979 F-100 & Larger F-Series Trucks 1 04-01-2011 09:11 PM
weld on axle wedges for dana 44 benmoderow Offroad & 4x4 0 09-26-2009 01:07 PM
Search this Thread:
Advanced Search
Posting Rules
You may not post new threads
You may not post replies
You may not post attachments
You may not edit your posts
BB code is On
Smilies are On
[IMG] code is On
HTML code is Off
Trackbacks are Off
Pingbacks are Off
Refbacks are Off
Forum Jump
