302 swap
Old 06-13-2014, 09:59 AM
Labdrool's Avatar
Labdrool
Labdrool is offline
302 swap
I have recently started a complete resto of a 1950 F1 and am stuck on building the motor mounts to install a 302 any ideas as to how to build them?
Old 06-13-2014, 10:26 AM
packrat56's Avatar
packrat56
packrat56 is offline
Pretty sure they are available to purchase? Or not for a 1950?
Old 06-13-2014, 01:21 PM
Wayne Waldrep's Avatar
Wayne Waldrep
Wayne Waldrep is offline
Old 06-13-2014, 01:27 PM
Wayne Waldrep
Sorry....also Welcome to FTE!!!!
Couple things. If you could, please go to your UserCP and put your location in so we can see where you are. Location is helpful at times. As far as mounting an engine other than factory and how to build engine mounts, we would have to know what you are building on...stock front end? custom IFS or swapped IFS? Many variables.
Old 06-13-2014, 01:39 PM
AXracer's Avatar
AXracer
AXracer is offline
I am helping another member with this same install right now. What front suspension are you using stock beam axle, IFS if so which one? His has a GM front clip with IFS installed. We are using these mounts on the engine:
http://www.summitracing.com/parts/an...view/make/ford
A bolt goes thru the ears at the bottom in the picture to a fabricated mount on the frame. The tubular mount Wayne linked to works well with the beam axle and doesn't require fabbing or welding. It may require switching the oil pan and oil pump to the Bronco rear sump style for clearance tho.
The rear tranny mount will need to be fabricated tho and will depend on what tranny you are using and if you have under floor brake master cylinder. do you have any metal fabrication tools, welder?
Old 06-13-2014, 01:40 PM
packrat56's Avatar
packrat56
Oh.. Gosh I'm sorry.. I did not notice it was your first post!
Welcome indeed! GREAT place... GREAT people!
Old 06-13-2014, 01:51 PM
AXracer's Avatar
AXracer
AXracer is offline
Keep telling up about you and your truck, add pictures, we LUV pictures (some of us can't read come here just to look at the pictures!) Once you have made 5 or more posts, they will let you look behind the curtain and a whole lot of useful functions will be made available to you.
Welcome!, this is a very friendly place, so pull up a computer and stay awhile!!!
Old 06-13-2014, 10:26 PM
dmack91's Avatar
dmack91
dmack91 is offline
The mounts AX referenced from Summit are the ones I used on mine, but I got them from NAPA. I made my own mounts from the frame to those using some 1/4" flat plate and some DOM tubing. Fairly simple. Mine were for a factory solid axle.
Old 06-13-2014, 11:14 PM
ben73058's Avatar
ben73058
ben73058 is offline
Hey Lab,
Good to see another '50 on here! Welcome Aboard!
Good luck on your build. Post some pics when you get a chance.
(If you find you are using the site regularly to help with your build - I'd join up. You get rid of the annoying ad's & you get a paperclip icon where you can post directly from your hard drive (very easy).
Ben in Austin
1950 F1 (351W/AOD)
Old 06-14-2014, 01:45 AM
underthebridgejim's Avatar
underthebridgejim
underthebridgejim is offline
FTE fan
Well heah there! I'm also a proud 50 F-1 owner. You have got a lot of good answers to your question so Im just going to give you a warm FTE welcome, and wait to see pics of your truck. It's good to have you.
Old 06-14-2014, 12:54 PM
arctic y block's Avatar
arctic y block
arctic y block is offline
Subscribing. Need pics as I am one that can't read
SonyResendiz
15
12-23-2016 04:18 PM
christurney77
1947 and Older Ford Trucks
01-02-2012 10:22 AM
73f100shorty
05-21-2007 07:34 PM
dixiefried
01-10-2007 01:20 PM
BlueOvalDrifter88
1983 - 2012 Ranger & B-Series
05-09-2005 09:59 PM
Quick Reply: 302 swap
