toyota steering box u-joints
were can i find a steering u-joint for the toyota steering box the classic haulers want $80.00 for theres is says it 11/16 with 36 splines speedway donot have it theres got to be some were out there lest than $80.00 dollers some one got to know about some haveing theys parts please let me know
I live a shelter life so please let me know and i know there are a lot of as
that don't know were to git there parts too thanks for your help the #1spudman
Summit has some that will fit Toyota on one end but you did not say what will connect to the other end. They are made by Borgeson and are only $4 less than Classic Haulers. Go to the Borgeson web site to see if they make what you need. If you are staying with the original steering column, then the u-joint from Classic Haulers is what you will need.
I got mine from Flaming River too. They were very nice and helped me get the right parts when I called and visited them.
The joint came with the box - not very attractive but it works fine, was free with the box, and fit directly to the rag joint of the 78-9 Ford van column I used. The column had to be shortened by 8 or 9", but has tilt, no key switch, and was only $9 from the scrap yard. I cut the brackets off and made my own drop bracket for mounting it to the dash.
morroccoz
02-19-2000 08:52 PM
