E4OD streaming fluid now not shifting into any gear
Old 06-12-2014, 02:44 PM
anelson2964's Avatar
anelson2964
anelson2964 is offline
My son was driving my F250 (big mistake) when as he says he noticed it was leaking transmission fluid. As he was driving it he noticed fluid coming out then it just stopped working.(motor was running but transmission would not pull in any gear) We towed the truck home and let it sit for about a week. Now it will start but when I try to shift it into gear it will run through the gears but there is no action. It will not engage into any gears.
Please HELP..
Old 06-12-2014, 03:17 PM
anelson2964
Info update
1992 F250 7.3 diesel
Old 06-12-2014, 03:30 PM
douglpr42's Avatar
douglpr42
douglpr42 is offline
first need to find where leaking from . maybe line to cooler or front or rear seal . leak would need to be repaired and refilled with fluid . then if luck is on your side will engage and shift ok if did not run too long low on fluid .
Old 06-12-2014, 03:32 PM
douglpr42's Avatar
douglpr42
post where leaking and somebody will guide you on how to repair .
Old 06-12-2014, 04:01 PM
stuart1's Avatar
stuart1
stuart1 is offline
Is there enough fluid in it?
Old 06-18-2014, 08:26 PM
anelson2964
Update !
We filled the transmission back up.
Good: no leaking
Bad: still won't shift/eengage into gear.
Any advise?
Old 06-19-2014, 02:17 PM
Mark Kovalsky's Avatar
Mark Kovalsky
Mark Kovalsky is offline
Received 1,576 Likes on 1,054 Posts
With the engine idling does the fluid show in the DO NOT ADD portion of the dipstick? If it does, then the trans is all done. If it is still low it may work again once it is filled.
NotSoSporty98
08-28-2016 03:06 AM
PO1
1999 to 2016 Super Duty
10-05-2014 10:38 PM
curt563
01-30-2010 10:07 PM
onepercheron
01-06-2010 01:22 PM
Quick Reply: E4OD streaming fluid now not shifting into any gear
