Easiest way to get manifolds out?
I'm working on removing the exhaust manifolds on our 460 powered 86 E350 motorhome, and I've made some progress on getting the manis out. I've primarily been going through the inside. What is the best way to get to all the bolts, specifically in the front? Is it worth the time to pull everything (fan, shroud, air pump, etc) out of the way?
Thanks
Jameson
Thanks
Jameson
Bump.
Got the drivers side out.
I've taken the radiator, air pumps, and alternator out, as well as the large bracket for all of it.
Issue I'm having now is with the heat shield/riser on the passenger side. Can't get it out of the way, and even if I pulled the motor mount/carb and tried jacking up that side of the engine I still wouldn't have room.
Any ideas?
Thanks
Jameson
Any ideas?
Thanks
Jameson
70FE250
33
08-19-2016 02:35 PM
quakerj
08-19-2013 02:17 PM
jclark4cs
02-06-2006 11:17 PM
