RSC icon on at random times....help - Ford Truck Enthusiasts Forums
2007 - 2014 Expedition & Navigator 2007, 2008, 2009, 2010, 2011, 2012, 2013 and 2014 Ford Expedition and Lincoln Navigator
Old 06-12-2014, 01:10 AM
ecyrbh ecyrbh is offline
ecyrbh is starting off with a positive reputation.
I have an 08 Expy EB 2wd and a month or so ago the RSC icon lit up on the dash for no apparent reason while driving on the highway at approx. 70-75 mph(in overdrive)...I tried to turn off the light by pressing the switch,but the light would not go away.The only way I got it to go out was to turn the vehicle off and restart it...Well,it happened to me again 3 times this week on a long trip while towing my travel trailer..It would come on randomly,and again was unable to control the light with the switch...The conditions that I was driving were 75-80 mph,up and down steep grades,in gusty crosswinds and headwinds as well,bearing in mind at times uphill speeds were significantly reduced to anywhere from 45-55 mph.All of the towing that I was doing was in manual 5th gear(on uphill grades) and in overdrive when able to on flat ground...I never noticed any reduction in performance or braking the entire time...Are there any common issues with the RSC system or could it just be the driving conditions I was experiencing???...Help
Old 06-12-2014, 09:30 PM
montecarlo31 montecarlo31 is offline
montecarlo31 is starting off with a positive reputation.
Check your steering position sensor. That's a common issues.
Old 06-12-2014, 10:53 PM
Would having this icon appear set a fault code for me to access with a scan tool????
Old 06-13-2014, 11:39 AM
pdqford pdqford is online now
pdqford has a good reputation on FTE.pdqford has a good reputation on FTE.
Quote:
Especially if you have had the front end aligned and they didn't check/reset the SAS.
Old 06-13-2014, 11:59 AM
Nope,..haven't had the front end aligned...
Old 06-13-2014, 10:14 PM
Quote:
Never had that issue and we do frequent alignments. I'm betting it's the sensor in the steering column.
Old 06-14-2014, 12:14 PM
Well I'm gonna have to look into the steering sensor,but still confused as to why I couldn't shut the light off by cycling the RSC switch on and off....
ABS RSC Warning Light Power Stroke 7107 Explorer, Sport Trac, Mountaineer & Aviator 6 01-04-2015 05:54 PM
2008 Explorer - RSC Issue LashLaRue Explorer, Sport Trac, Mountaineer & Aviator 1 01-01-2014 03:33 PM
superduty E-350 problem with the RSC 6t56 1999 to 2016 Super Duty 0 12-30-2009 10:56 AM
RSC Alarm going off! need help. Blowinsmoke 1968-2013 Full Size Vans 3 09-04-2009 10:23 PM
RSC and traction control moonunit7317 2007 - 2014 Expedition & Navigator 0 11-27-2007 07:24 PM
Search this Thread:
Advanced Search
Posting Rules
You may not post new threads
You may not post replies
You may not post attachments
You may not edit your posts
BB code is On
Smilies are On
[IMG] code is On
HTML code is Off
Trackbacks are On
Pingbacks are On
Refbacks are On
Forum Jump
