Project Daily Driver, 1990 F250 - Page 3 - Ford Truck Enthusiasts Forums
  #31
Old 08-04-2014, 05:50 PM
emspjay's Avatar
emspjay emspjay is offline
emspjay is gaining momentum as a positive member of FTE.emspjay is gaining momentum as a positive member of FTE.
Quote:
Originally Posted by Truck Guy99 View Post
Do you have pics of the orange peel? I'm about to do a brake job too but I'm having trans problems now
I looked at your video earlier today on the trans problem, My laptop has crappy speakers so I was having a hard time hearing what that noise is.
I just went outside and got a few new pics for you. I haven't washed the truck in over a month with all the rain here. The first pics show the area with orange peal, then a few of the rest of the truck. Most of the truck is perfect. Maaco does not wet sand and rub out paint, so how it came out of the painters gun is what you get. (you get what you pay for) You can see he did a good job on most of it, I'm just a little **** about it because I used to do it for a living. But it's not a big deal and if I get bored this winter I will wet sand and rub out the paint.
  #32
Old 01-11-2015, 11:19 AM
GIGGER's Avatar
GIGGER GIGGER is offline
Posting Legend
GIGGER has a superb reputationGIGGER has a superb reputationGIGGER has a superb reputationGIGGER has a superb reputationGIGGER has a superb reputationGIGGER has a superb reputationGIGGER has a superb reputationGIGGER has a superb reputationGIGGER has a superb reputationGIGGER has a superb reputationGIGGER has a superb reputation
Great build Jay, thx for sharing
  #33
Old 01-11-2015, 11:39 AM
emspjay's Avatar
Quote:
Thank you Gigger!
Haven't updated thread since stuff I have done is not very picture worthy. But I have also done front brakes/lines, rear diff fluid, rear fuel pump/sender, starter, solenoid, cables, water pump, hoses, coolant, O2 sensor, IAC, MAP sensor.
Still need to change trans fluid/filter. Going to make new cooler lines since they are rusty and put a bigger cooler on it. The factory tow package cooler looks to small to me.
The best part is I sold my 2011 Ram when I finished this in August. That Ram cost me $600 a month so not paying for that this F250 has almost already paid for itself.
  #34
Old 01-11-2015, 11:46 AM
GIGGER's Avatar
Posting Legend
Jay I'm a transmission man & I think the trans will need fluid & a new screen & theres a drain plug in the torque too, may as well drain it all huh
the srceen has one screw thats longer than the rest, take note of its location
theres a 2wd screen & a 4wd screen, make sure you get the right one
is it shifting OK
  #35
Old 01-11-2015, 12:02 PM
Redneckfordf2502002's Avatar
Redneckfordf2502002 Redneckfordf2502002 is offline
Redneckfordf2502002 has a superb reputationRedneckfordf2502002 has a superb reputationRedneckfordf2502002 has a superb reputationRedneckfordf2502002 has a superb reputationRedneckfordf2502002 has a superb reputationRedneckfordf2502002 has a superb reputationRedneckfordf2502002 has a superb reputationRedneckfordf2502002 has a superb reputationRedneckfordf2502002 has a superb reputationRedneckfordf2502002 has a superb reputationRedneckfordf2502002 has a superb reputation
Not sure how you feel about these but with the tail lights you have I think these will look great on your truck:
Ford F-Series and Bronco 87-92 |
Trav
  #36
Old 01-11-2015, 12:45 PM
emspjay's Avatar
is it shifting OK
Going to drop the pan put in new screen/filter and and drain the torque converter.
It shifts good, I just want to do it because I don't know how old the fluid is.
  #37
Old 01-11-2015, 12:47 PM
emspjay's Avatar
Trav
Thanks for the link Trav! Those are aewsome!! I wish I knew about those before I got mine. I think I will get a set and then try to sell mine on Ebay.
  #38
Old 01-11-2015, 12:55 PM
They are the only ones that makes the clear corner light for the 87-91s.
I personally also like them I plan to put them on one or a few of the trucks we have.
Trav
  #39
Old 01-11-2015, 12:59 PM
GIGGER's Avatar
Posting Legend
Sounds good, a small shift kit would help or if its fine then just a service will help for sure,
She's a 'honey for the money' ....
  #40
Old 01-11-2015, 04:05 PM
emspjay's Avatar
LOL! Yep been putting some money in her but its all just really preventative maintenance now after making it look good.
Oh and I forgot I had to replace that stupid cast aluminum arm thing in the steering column. That was the only time it left me stranded since I got it. It broke in the morning in the driveway before work. So had to have a friend from work pick me up and take me home. While on the way home we stopped at the parts store and I got the cast arm thing, ignition switch, and new key switch/tumbler. Figured if I had to take it apart to replace the cast arm thing I would just do the other stuff as well.
  #41
Old 01-11-2015, 04:08 PM
The dreaded ignition actuator. I hate that thing. It is ready to go on the 90 F150.
So glad my 88 F150 doesn't have one.
Trav
  #42
Old 01-11-2015, 04:56 PM
emspjay's Avatar
I want to keep this truck as my daily driver for at least 3-4 years. And then start building my dream truck in 2-3 years. Ford never made my dream truck so I will have to build it myself.
Dream truck is 1993-1996 F350 Crew Cab Short Bed 4x4 Dually, not sure if I will do a 460 or a 7.3 Diesel. Did Ford make a CCSB F350 single wheel 4x4? Or will I have to convert a F250 CCSB 4x4?
  #43
Old 01-11-2015, 05:12 PM
That did but I think it was 96 and 97 only. Diesel Brad has one that he converted to dually then back to SRW.
Here is the link to his thread: http://www.ford-trucks.com/forums/11...csb-build.html
Trav
  #44
Old 01-11-2015, 06:27 PM
NFLD FLARESIDE's Avatar
NFLD FLARESIDE NFLD FLARESIDE is offline
NFLD FLARESIDE is starting off with a positive reputation.
Sweet truck!!!!
  #45
Old 01-11-2015, 07:58 PM
emspjay's Avatar
Quote:
Originally Posted by NFLD FLARESIDE View Post
Sweet truck!!!!
Thank you!!!
Do you have any threads on your trucks?? I love Ford trucks! I had a 2001 F150 CC 4x4 5.4 and a 2008 F150 CC Limited AWD. I need to find some pics of those trucks. The 2001 died on my way to Alaska in 2008 (shot a spark plug out of the head). So I was in a little town in WA when that happened with a full truck and the brand new 2008 F150 Limited was the cheapest truck the Ford Dealer had on the lot (the rest was F250, 350 and Harley's). Got screwed on my trade in also on the 2001 but I had to be on the Alaska Ferry to Ketchikan AK the next day.
1/2 ton, 3/4 ton, or 1 ton Truck Guy99 1987 - 1996 F150 & Larger F-Series Trucks 57 03-04-2014 11:18 AM
can i swap suspension from 3/4 ton to 1/2ton demotrucker 1987 - 1996 F150 & Larger F-Series Trucks 3 08-30-2013 07:32 AM
Number/Tonnage Equivalent benjamin09 Large Truck 6 04-23-2013 08:18 PM
will f250 rear leafs bolt right up to f150 leaf mounts? FordOwnerJoey 1987 - 1996 F150 & Larger F-Series Trucks 12 06-21-2012 07:18 AM
What does 1/4 ton, 1/2 ton, 3/4 ton mean? 76F250HighBoy 1973 - 1979 F-100 & Larger F-Series Trucks 23 05-13-2011 07:46 PM
Search this Thread:
Advanced Search
Posting Rules
You may not post new threads
You may not post replies
You may not post attachments
You may not edit your posts
BB code is On
Smilies are On
[IMG] code is On
HTML code is Off
Trackbacks are On
Pingbacks are On
Refbacks are On
Forum Jump
