Project Daily Driver, 1990 F250 - Page 2 - Ford Truck Enthusiasts Forums
Old 06-15-2014, 05:22 PM
The other Joe The other Joe is offline
The other Joe is starting off with a positive reputation.
Nice job. I'm glad your happy with the outcome.
I do paint and body and know how much labor is involved.
Black is a bi/$h to keep clean, but looks so nice when it's done
Joe W
Old 06-15-2014, 07:13 PM
emspjay's Avatar
emspjay emspjay is offline
emspjay is gaining momentum as a positive member of FTE.emspjay is gaining momentum as a positive member of FTE.
Joe W
Thank you Joe!
I applaud you for being in the paint and body business! It has been so long for me I forgot how much work it was! LOL! Other than some wet sanding and rubbing out old paint with my Makita wheel on other cars this was the first body work I have done in 13 years!
Old 06-15-2014, 07:35 PM
TheCoach TheCoach is offline
TheCoach is starting off with a positive reputation.
Great stuff... If i could get mine looking like that one day Id be a happy guy.
Old 06-15-2014, 08:57 PM
emspjay's Avatar
Coach, all it takes is a little bit of free time I got this truck less than 2 months ago.
So here is the current tally on cost for this since the main goal is having a nice daily driver 3/4 or 1 ton truck on a budget. (and i'm going to sell my 2011 1500 Ram and get rid of that $530.00 a month payment when this F250 is done)
Truck purchase $1600.00 cash
New tires and wheels $830.00 shipped to my door (discount tire direct)
New Lug nuts $35.00 shipped (Ebay)
VA inspection $16.00 (truck passed with flying colors!)
New Tailgate $138.00 shipped (LMC Truck)
New Paint Maaco $600.00
Rear brakes about $150 in parts (advance auto) did everything myself and bent and flared the new lines)
About $40.00 in MISC door/window and tailgate seals from LMC truck.
New headlights, taillights, grill $280.00 (Ebay)
Change oil, air filter, new wipers about $60.00 (advance auto)
New front fuel tank pump/sender $120.00 (advance auto)
I will say about $300 in misc sandpaper, primer, paint, etc.
New door stereo speakers $33.00 (Ebay) Replaced those when I had the door panels off for painting it black.
Old 06-15-2014, 09:13 PM
emspjay's Avatar
Now here is the "To Do List"
Fix the A/C
New rear tank fuel pump/sender
New front brakes and lines
New stereo
Spray in bed liner
Fuel filter
Change trans fluid
Change coolant
Change rear end fluid
New U-joints
Tint the windows
Tonneau cover for the bed
Old 06-16-2014, 09:56 AM
Truck Guy99's Avatar
Truck Guy99 Truck Guy99 is offline
Truck Guy99 has a good reputation on FTE.Truck Guy99 has a good reputation on FTE.Truck Guy99 has a good reputation on FTE.
Quite a transformation. Thanks for doing the cost breakdown, it really helps. How long did it take you to replace the fuel pumps? And did you drop the tanks or pull the bed? I plan to paint mine black with the same wheels as those when I get some cash together. Again, great job and keep us posted!
Old 06-16-2014, 06:24 PM
emspjay's Avatar
Quote:
Thank you! I have been following your thread also, great work! I would have liked to have a 4wd beast like yours but I had a hard time finding one and gave in on this 2wd truck.
I only did the front tank pump/sender so far. I used ratchet straps to lower the tank and raise it back up (low on fuel so not heavy), took me about 2 hours. I haven't done the rear tank yet or even remove the spare tire to see if I can do the ratchet straps on it or if I need to pull the bed up.
Got A/C fixed and converted to R-134 today so add $370.00 to the total.
Old 06-21-2014, 05:18 PM
emspjay's Avatar
Got the emblems and windshield trim back on.
Got the DIY Spray liner done. $60.00 (advance auto)
Got the new stereo in $60.00 (Ebay got stereo and install kit)
Old 07-08-2014, 10:00 PM
emspjay's Avatar
It's been awhile since I updated. I have been driving the truck everyday and enjoying the hell out of it!
New Tonneau cover $200.00 Shipped (anything auto)
New door strikers $18.00 (advance auto)
Tinted the back windows with 20% (still have to do the side windows with 35%) Purchased all the tint stuff from advance auto for $30.00
Some of the new pics are with flash off and flash on (I can't take good pics so I will post them all)
Old 07-09-2014, 03:12 PM
Looks sharp! What color did maaco call that and did they do a good job? It looks great in the pics but I know black lays down like a mirror for imperfections. And where did you get the tail lights?
Old 07-09-2014, 04:02 PM
emspjay's Avatar
Thank you! It's just a single stage straight gloss black. Yep you have to do a really good job with your body work if you paint it black (took me about 1 month). Maaco did a good job spraying it, a little orange peel in some spots but not bad. It still looks great. I might wet sand and wheel it out this winter if I get bored, that's not on my priority list since it's a daily driver and not a show truck. I got the taillights on Amazon.com. I barging shop everything, Amazon, Ebay, etc. If I know what I need before I will go to Advance Auto website and order everything and use a coupon code, then pick it up at the store the next day on my way home.
Old 07-09-2014, 04:41 PM
Bootlegger's Deluxe's Avatar
Bootlegger's Deluxe Bootlegger's Deluxe is offline
Bootlegger's Deluxe is starting off with a positive reputation.
looks great man! ive done a few of those "60 day transformations" itr makes you feel so proud, dont it?
im curious as to what wheels you used, any info on them?
  #28
Old 07-09-2014, 05:04 PM
emspjay's Avatar
Thank you! Yes I agree it sure does! This is my first car/truck project since I joined the Military over 13 years ago. I went to tech school after High School and was a mechanic/body tech for about 6 years before the Military.
Below is the link for the wheels, Discount tire direct. Got wheels/tires for $830 shipped to my door. Went with standard wheel size and standard size/load capacity tires for the truck. Wanted to make sure I have the correct load capacity for the truck since I tow a boat. Being safe loaded and towing is more important than looks.
Wheel Details - Discount Tire Direct
  #29
Old 08-04-2014, 04:56 PM
emspjay's Avatar
So over the weekend I did new front rotors, pads, and brake lines. And it still had the original spark plugs, wires, cap and rotor so I did all those also. So ad $300 to my total cost.
Since the coil is also original I think I should also replace that, do you guys think I should get the MSD Coil or the Accel Coil?
Truck has been running great and I have been getting 11mpg with the A/C on full blast. I think this is good and I'm happy with that. I drive easy trying not to go above 2000rpm, the only time I'm above 2000rpm is on the highway with the 4:10 rear I'm at 2100-2200rpm at 65mph. Much better than my old 85 F350 CC dually 460/C6 got 6-8mpg
  #30
Old 08-04-2014, 05:32 PM
Do you have pics of the orange peel? I'm about to do a brake job too but I'm having trans problems now
1946 1/2 ton & 3/4 ton chassis 44jailbar 1947 and Older Ford Trucks 3 03-21-2015 10:32 PM
No market for a 3/4 Ton SUV? Pele Excursion - King of SUVs 16 07-18-2014 02:17 PM
1/2 ton, 3/4 ton, or 1 ton Truck Guy99 1987 - 1996 F150 & Larger F-Series Trucks 57 03-04-2014 11:18 AM
1/2 ton to 3/4 ton stromburg 1973 - 1979 F-100 & Larger F-Series Trucks 1 10-17-2012 11:33 AM
Trying to swap HD f250 extended cab front end onto my truck Malahki 1973 - 1979 F-100 & Larger F-Series Trucks 4 06-08-2009 03:30 AM
Search this Thread:
Advanced Search
Posting Rules
You may not post new threads
You may not post replies
You may not post attachments
You may not edit your posts
BB code is On
Smilies are On
[IMG] code is On
HTML code is Off
Trackbacks are Off
Pingbacks are Off
Refbacks are Off
Forum Jump
