wont go into gear
Old 06-11-2014, 07:24 PM
big-B's Avatar
big-B
big-B is offline
wont go into gear
my 05 excursion wont go into gear some times I have to push the brake pedal a few times to get it to go any ideas
Old 06-11-2014, 07:39 PM
Psyclopse's Avatar
Psyclopse
Psyclopse is offline
Does the shifter feel sloppy? Does it take a little "slam motion" to get it into park sometimes? You might have worn out bushings on the shifter tube on your steering column, and/or you might have the two bolts on the back of the shifter tube coming loose. I just did this repair on my truck.
Info here:
https://www.ford-trucks.com/forums/1...r-rebuild.html
Old 06-11-2014, 07:40 PM
Mark Kovalsky's Avatar
Mark Kovalsky
Mark Kovalsky is offline
Received 1,570 Likes on 1,049 Posts
Or your brake light switch may be failing. The shift handle lock is released by the brake light switch.
Old 06-11-2014, 07:44 PM
Misky6.0's Avatar
Misky6.0
Misky6.0 is offline
Try turning steering wheel both ways with key on, sometimes it will be tight against the stop and lock the gear shifter.
Sent from my Sprint PC36100 using IB AutoGroup
Old 06-11-2014, 11:41 PM
Vwags's Avatar
Vwags
Vwags is offline
+1 You can try to see if the brake lights come on when you are trying to get it out of park.
Old 12-26-2015, 05:05 PM
Jesser02EX's Avatar
Jesser02EX
Jesser02EX is offline
I'm dragging up an old thread instead of starting a new one...
My 02 EX with adjustable pedals will do this time to time after a long drive. I put it in park at a gas station or parking spot and without killing the motor it won't go back to "D". I get out and look under the dash, giggle stuff around and it usually works.
Can you help me with what to inspect on this problem? I can confirm the two torx bolts are tight. I'm looking for the break switch Mark references above?
It looks like I have a motor connected to both pedals, one wire harness on the break and two on the accelerator pedal. What I don't see are serviceable switches on either pedal.
Has anyone done a write up? I didn't see one in the Tech folder. Wanted to ask as I search to resolve this issue.
Old 12-26-2015, 06:49 PM
projectSHO89's Avatar
projectSHO89
projectSHO89 is offline
The brake lights check in post #5 isn't valid. They're on a separate circuit from the one that releases the shift interlock. It's a double pole switch....
The brake pedal position switch is up there on the brake pedal support. Keep looking you'll eventually find it.
A good number of times, it isn't the switch that goes bad, it's one of the wires that goes to the connector for the switch. They can break inside the insulation and become a real PITA to find.
NewXer
06-20-2015 04:39 PM
afonda
03-09-2012 09:50 PM
bill012
02-23-2007 06:40 AM
Scorpion_DvT
1997 - 2003 F150
09-25-2005 06:27 PM
EZTrader
1978 - 1996 Big Bronco
09-09-2003 05:03 PM
Quick Reply: wont go into gear
