Rear turn signals? (63 flareside) - Ford Truck Enthusiasts Forums
Old 06-11-2014, 05:22 PM
n10z n10z is offline
n10z is starting off with a positive reputation.
Slowly working on a 63 f100 Flareside. Ordered new tailights and brackets from LMC, kind of figuring they would have turn signals in them. Not looking like it. Where were the OEM rear turn signals?
Old 06-11-2014, 06:41 PM
P38fighter P38fighter is offline
P38fighter is gaining momentum as a positive member of FTE.
What do you mean by " turn signal in them?" The bulb is a two filament bulb to provide a low running light and bright turn and brake .
Old 06-11-2014, 07:59 PM
The after market tail lights on it now have 3 wires, the signal wire is triggered by an aftermarket turn signal (the one from LMC). The new tail lights that I ordered only have 2 wires.
I have a feeling this is going to turn into a much larger project then anticipated.
Old 06-11-2014, 09:00 PM
I think the green and yellow is correct. The black is probably a ground for the aftermarket light. Original ones grounded through the light itself.
Old 06-11-2014, 09:20 PM
NumberDummy's Avatar
NumberDummy NumberDummy is online now
Ford Parts Specialist
NumberDummy has a superb reputationNumberDummy has a superb reputationNumberDummy has a superb reputationNumberDummy has a superb reputationNumberDummy has a superb reputationNumberDummy has a superb reputationNumberDummy has a superb reputationNumberDummy has a superb reputationNumberDummy has a superb reputationNumberDummy has a superb reputationNumberDummy has a superb reputation
Upper pic: 1955/66 Flareside "shield" tail lamps. 1955/60's have FORD molded into the lens, 1961/66's were plain.
The left lamp incorporates the license plate lamp. The mounting brackets and the license lamp bracket are the same as used with the round lamps. that were used 1953/54.
LMC's aftermarket lamps are sorta similar to what FoMoCo began installing in 1967, as they incorporate backup lamps.
Old 06-12-2014, 08:43 AM
svolpone's Avatar
svolpone svolpone is offline
svolpone has a great reputation on FTE.svolpone has a great reputation on FTE.svolpone has a great reputation on FTE.svolpone has a great reputation on FTE.svolpone has a great reputation on FTE.svolpone has a great reputation on FTE.
Quote:
Oh, that is a big "for sure", dude. you're just getting started. lol.
Dash Lights greenf150flareside 1980 - 1986 Bullnose F100, F150 & Larger F-Series Trucks 3 08-31-2015 10:23 AM
Turn signals bks976 1999 to 2016 Super Duty 2 07-12-2015 06:06 PM
58 to 63 flareside swap? schweinhaus 1961 - 1966 F-100 & Larger F-Series Trucks 1 07-23-2014 03:42 PM
'63 F100 Turn Signal problem pburress 1961 - 1966 F-100 & Larger F-Series Trucks 5 07-15-2014 12:57 AM
Aftermarket turn signal problem. Please help! jhaas63 1948 - 1956 F1, F100 & Larger F-Series Trucks 8 01-03-2014 07:20 PM
Tags
1963, brake light, f100, flareside, tail light, turn signal
Search this Thread:
Advanced Search
Posting Rules
You may not post new threads
You may not post replies
You may not post attachments
You may not edit your posts
BB code is On
Smilies are On
[IMG] code is On
HTML code is Off
Trackbacks are Off
Pingbacks are Off
Refbacks are Off
Forum Jump
